Cobra 29XLR No Signals In or Out
kenwoodgeek
Wheaton, IL
This is the second post about this darn setup I purchased at an estate sale.
I've been trying to get the locks that are covering the mounting bolts off with no luck, so I might need to take the whole thing to a locksmith so I can remove the radio from the external speaker.
I finally had a chance to test the thing today, and I think I might need a new radio. I had it plugged into power and a magnet mount, but I was getting absolutely no signal in. No sound, and the meter was not jumping at all. When I went to key the mike, absolutely nothing but a little static sound from the mike itself, for some reason.
I won't go into detail, because I made a quick YouTube video to show what I am talking about. Like I said, I'm guessing I have a bad radio, but I could also be doing something wrong.
Here is the link: https://www.youtube.com/watch?v=XRS5AUTSGyU
Thanks!
ipfd320
Banned
W.Babylon N.Y. 11704
on the Radio mike jack-----Try Jumping Out Pins 1 & 3 (Txmitt Pins)--If that works then its the Mic Problem---For Rxcieve jump out pins If i Remember Correctly 2 & 4 or 1 & 4
Another way to Check to see if the Finals are Blown--Hook a Speaker up to the Pa Jack and See if you Have Audio if so Tx Finals are good
Good luck --the xlr is a good radio--That was my 1st radio i used back in the day
kenwoodgeek
Wheaton, IL
Thank you for that.
I didn't jump out the pins, because I remembered I had a pretty much brand new 4 pin mike in one of my boxes that was working fine last time it was being used.
I plugged that in and tried again but to no avail. This time, each time I keyed the mike, there was a very, very faint pop coming out of the external speaker. Still no movement from the SWR meter at all. I plugged the external speaker into the PA jack and switched the radio to PA mode. Keyed the mike and absolutely nothing.
prcguy
The TX finals (RF output transistor and driver) have nothing to do with audio coming out of the PA speaker jack into a speaker. You can remove the finals and the PA audio system will still work fine. The front panel meter is a basic indication that RF is coming out but an external wattmeter will tell a better story.
The radio could be toast or the OP may have a mic with a different pinout. If its a new mic the pinout on a 1970s or 80s vintage radio may be different, even for the same model. I would try shorting the pins as suggested by someone else to see if RX or TX comes alive.
kenwoodgeek
Wheaton, IL
Thank you, everyone! Shorting the pins with a wire gave me transmit and receive. I tested with my scanner, and it received the signal. The sound was kind of getting quieter and louder, but I'm sure that's because I was just using a wire. I think it's flipping retarded that you need a mike plugged in to receive a signal.
The radio's SWR meter jumped just a little bit when I went to transmit. Not sure if that means my SWR is good or bad, but I'll need to purchase a meter to tune my mag mount.
Unfortunately, I don't have a Cobra mike, so I'll have to buy one. Any particular one I should look for?
