arkieguide
ARRL
c. RF ground.
This is required only for certain types of antennas-- ones which require current flow to ground to complete
the antenna circuit. An example is a quarter-wave vertical. One wire of the feedline connects to the base of the antenna, and the other connects to ground. The connection to ground has to have a low RF resistance, or you'll expend too much of your power heating the ground. A few radial wires will provide a moderately low loss connection. A ground rod will help a little, but the RF resistance will be high, resulting in quite a bit of loss.
Chapter 8 of the ARRL Antenna Book shows the approximate trade between resistance and number of radials. If your antenna is much shorter than ¼ wavelength, you'll need many, many radials to get reasonable efficiency. If it's longer, you can get by with fewer. A ½ wavelength base-fed vertical needs only a very modest ground, and a ground rod is adequate. The requirements for various other end-fed
antennas depend on their length. If you use a "complete" antenna like a dipole or a ground plane (that is, one that doesn't require your feedline to connect to ground), you don't need a RF ground, as long as you keep common-mode currents off your feedline. A "current" or "choke" balun is most commonly used for this.
c. RF ground.
