Hillcotech
Greetings,
I work for an Ag manufacturing company that makes products for John Deere and Case IH Combines. Almost all of these combines have CB's in them. When the mic on a CB is keyed the rf signal is causing adverse affects. The RF signal is affecting a slope sensing clinometer causing it to output a higher voltage which is then read by our controller which then causes the controller to output undesired signals. We have had success grounding the cb antenna, shielding harnesses with tin foil, redoing our power and ground to where we are direct to the battery however what works on one combine does not on the other. Is there something that we can do with our wiring harnesses that will completely eliminate this so regardless of a poorly grounded antenna or whatever our system will not be affected? We are looking into ferrite beads however there is a lot to that also. Any suggestions are greatly appreciated.
