NMO caps plastic....whomp whomp...
Delivers1234
Monterey, CA
So i have 3 antennas (2m/70cm), cb and gmrs, NMO styles. I keep NMO rain caps on the 2m/70cm and cb. I guess sometimes when I power up just to listen on one antenna, i key up and killed the center pin wire. because the NMO cap was touching the center tip and the outside (where it screws to).
they will be reinstalled. I need taller NMO caps where the top of the cap does not touch the center tip. or I guess plastic?
any ideas...also one nmo mount has that rubber seal that is tapered outward due to the coil.
mrweather
The Larsen NMO rain caps are all plastic (except for the threaded base which is brass). The also come with a rubber base gasket.
Not sure what kind of rain caps you were using before that would short out the centre pin?
Delivers1234
Monterey, CA
It was the brass ones. the color is tinted in the cap as well as a shadow circle on the nmo cap. I guess i pressed it too much. I didnt think there was n electrical connection.
12dbsinad
Probably using a metal rain cap (chrome or black) i suspect?
Get a larsen model NMOCAPB, problem solved as it's non metallic.
