Can Linear blow cb radio final
larbian
I have an old 23 channel ssb that was puting out on AM about 5 watts. I turned on my 50 watt linear and keyed the mic and they both grunted and now the cb transmits 1/2 watt and if I turn the linear on its 1.5 watts.
Can the linear cause this and how many amps should the linear need? I think my supply is 5amps.
Thanks to all
zz0468
QRT
Banned
My first guess would be that the radio is fine and the power supply is blown. Did you check voltages?
RFI-EMI-GUY
Your power supply is inadequate to power a 50 watt amplifier. It may be damaged.
In turn it might have damaged the radio and amp if you shorted a pass transistor in the supply. Measure the voltage, is it still about 13 or 14 VDC?
You need a 20 amp supply to fiddle with that.
Unless the amplifier connections were reversed, it normally cannot damage the CB.
RFI-EMI-GUY
Also you cannot measure SSB with a standard power meter. You need a PEP power meter.
larbian
I tried it on am. It has a Redco digi scan attached and tuned in to channel 15. The CB and the linear were on separate power supply's and they both grunted when mic keyed. I will check voltages on the radio.
So do I need a separate meter because the radio is an ssb or if I was on one of the bands. I think the Redco bypasses the tuner and don't know if it bypasses the Am Lsb Usb switch.
larbian
Also, I connected the swr meter without the linear. Radio, SWR, Antenna. 1/2 watt. then I connected the swr between the linear and the antenna. Radio to linear to swr to antenna. 1.5 watt output.
RFI-EMI-GUY
I cant help you on that Redco, but I think it is made for 40 channel radios.
Are you using a proper antenna? Sounds like either you are getting RF into the power supplies or you dont have a powerful enough power supply. Check the basics.
larbian
Sorry, I am confusing my two radios. This one is a 40 channel.
RFI-EMI-GUY
Check your power supply voltages. No other advice can help you till you do this. If you dont have enough amps, you cannot get the watts. OHMS law..
jassing
Shelton, WA
I think the answer to your question is yes. If your antenna system is not tuned, then the reflected power can damage a radio. The simple test is to remove the amp and see if you are transmitting
