coax length
Niagara, Canada
hey everyone. I've got an Uniden with a proper mag mount antenna and the coax is only about 10 to 12 feet which is not long enough for me. If I was to get about 25' foot extension would my scanner still work right? Or would that throw everything off? I can only seem to find 25 foot cords and I'd have to use a BnC connector joiner, but I'm worried it won't work properly. Or should I buy a new antenna with a longer cord? Looking for advice. I listen to OPP EMS and FD and MTO if that helps with freq range.
thanks
gonefishn1
Clark County Nevada
You don't want a lot of extra coax that you don't need because of loss. So its best to get a cable made to the length you need. There are plenty of places that make custom length cables. Or you can get the connector and crimper and make it yourself.
Niagara, Canada
ok guess ill maybe talk to the place i bought this antenna in toronto and maybe see if i can get one made with about 20' its just too short. i almost think its only 10'
thanks
I agree, it's not going to hurt anything.
Yes, it'll add some more coaxial cable losses, but that'll happen if you build a custom mount with extra cable. There is going to be a tiny bit of additional loss from the extra connectors, but unless you have high end test equipment, you'll never know it's there.
Just add what you need. Next time you replace the mag mount, get one with longer cable.
n9mxq
Belvidere IL
A good reference for loss.. Coax Attenuation Chart
A good RG-58 at 100 foot long shows 4.8db loss.. so your 25 foot addition would add 1.2db of signal loss.. and at VHF I doubt you'd notice it at all unless you were on the fringe of the system
Rred
Just buy a good quality coax, and wrap the joint (connection) with something like Coaxseal or self-fusing butyl tape (or silicone) to ensure it is watertight, if it is going to be outside the vehicle.
bharvey2
Please, no butyl. If you ever need to get at that connection in the future, you'll regret using butyl.
Instead, use the tape SlicerWizard recommended. If your near a Home Depot, this stuff is very similar: https://www.homedepot.ca/en/home/p.scotch-130c-linerless-rubber-splicing-tape.1000101995.html
Oh yeah, butyl can be a nightmare. However, before using it, wrap the connector with a thin layer of teflon tape. Then overlay with butyl tape. The butyl still needs to be in direct contact with cox at each end of the wrap to maintain a weathertight seal. When the time comes that you need to remove the butyl, you don't have near the amount of frustration.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Even using a "courtesy wrap" of electrical tape is frowned upon although it's better than straight butyl.
Butyl gets everywhere and can be a real sticky mess. Our rigging crews will let you know exactly how they feel about it when they encounter it.
We were supplied butyl for temporary repairs and the riggers confiscated it as soon as they saw it. They were quite happy to hand out rolls of Scotch 130C tape to replace it.
