Information I learned at a meeting tonight...
Although plans are progressing for El Paso County to upgrade from the P16 system it now operates on to a full P25 system, it appears that it may be awhile before it can join the state DTRS. The problem appears to be in the version of firmware that El Paso County will upgrade to vs the firmware the state is using. Apparently, when El Paso County upgrades, its firmware version will be the most current version (all previous versions being obsolete and no longer supported by Moto) while the state system is several versions behind. The two versions are not compatible. For El Paso County to join the DTRS network will require the state to invest a few million dollars to upgrade to the latest firmware, and it's a few million dollars it doesn't have.
There has been some talk with installing a patch between the El Paso system and the state system (probably at the Cheyenne Mtn site), but it appears that that is not as easy as it would seem to be.
Long story made short: don't expect to hear El Paso County on the DTRS anytime in the near future.
