Thornton Police Department
cool1035
Does anyone know what the frequencys are for the Thornton Police Department? I use a BaoFeng BF-F8+
cool1035
Radio
Does the Vertex Standard VX-354 have the ability to trunk and listen into the thornton police department?
abqscan
DataBase Administrator
Moderator
AOA
No. You will need a receiver that supports P25 digital voice and trunking.
cool1035
Are you sure? My school uses this radio and the school is on a P25 trunking system.
Spitfire8520
I might be completely clueless! =)
Colorado
I would suggest buying a scanner. Getting a real P25 radio to listen to a P25 system is pricey, is very difficult, and can get you into trouble.
What you need is something that support P25 Phase I at a minimum, although getting a P25 Phase II scanner might be a good idea if they were to switch the radio system to the newer digital mode. A full list of P25 scanners can be found below.
Phase II Scanners:
Note: Phase II scanners are backwards compatible and support Phase I.
Phase I Scanners:
An alternative if price is a large issue for you is to investigate RTL-SDR. It is a lot more involved, has some quirks, and can be difficult to get setup. There are plenty of posts at Software Defined Radio and Voice/Control Channel Decoding Software regarding this. RTL-SDR Tutorial: Following Trunked Radio with Unitrunker would be a good starting point. It will require 2 of these devices, a dedicated computer, and several different software. To reiterate, this is not meant to be an easy way of listening to Thornton Police. I would suggest getting a scanner if you want something portable or if you are looking for a way to easily listen to Thornton Police.
Spitfire8520
Colorado
