Denver PD, FD,EMS & DIA....
Spirit
Larimer County
Denver PD, FD, EMS & DIA....What freq's should I have in LCN? I see they have 5 red CC & 15 freq's light black color. Right now I have all Freq's listed 1 thru 20 is that right or should I just have the red CC's in for all of Denver?
Should I have the TG ID's listed as DEC numbers or AFS numbers in my PSREdit500 program?
002 (2) Simulcast 01 854.9875C 02 855.4875C 03 855.9875C 04 856.4875C 05 857.2375
06 857.7375C 07 858.4875 08 859.2375 09 859.7375 10 854.4375
11 855.2375 12 855.7375 13 856.2375 14 856.7375 15 857.4875
16 858.2375 17 858.7375 18 859.4875 19 854.0625 20 854.5625
Spitfire8520
I might be completely clueless! =)
Colorado
For EDACS, you will need all the frequencies in the exact LCN as shown in the database. This is how the scanner will know which frequency it needs to go when system gives the it a channel number.
I believe it depends on the "TGID Format" Global Setting. Default (normal) should be AFS if you have not touched that setting. If you change that setting to DEC, then it would use the DEC numbers.
