Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Colorado Radio Discussion Forum
Colorado Radio Discussion Forum - Forum for discussing Radio Information in the State of Colorado.
Old 06-24-2018, 2:58 PM
Default Pitkin County
When will the Radio Reference database for Pitkin County be updated to the 800mhz frequencies?: ULS License - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Conv License - WQYB434 - Pitkin County - Frequencies Summary
The 2m frequencies are no longer utilized in Pitkin County yet are still listed as currently updated by Radio Reference? As I understand it the Whistler EZ Scan software uses Radio Reference for updating the library, and I am unable to update a Whistler WS1080 with the current frequencies.
Perhaps there is some manual workaround which I will have to figure out.
Old 06-25-2018, 3:31 AM
Spitfire8520's Avatar
Most of their public safety operations are on the State of Colorado DTRS, which you can import if you are using EZ Scan. You can see appropriate sites to program using the site map for the system.
It is possible to use EZ Scan to create custom objects by selecting adding something "New" instead of importing it from the database. This can be used to discover frequencies that are being used, but have not been identified in the RadioReference Database.
I do think that most of the VHF frequencies in Pitkin County can be marked with a "Deprecated" tag or even removed, but it requires a submission by someone in the area who is able to confirm that those channels are no longer being used. The Database is largely made up of information provided by the community, so it is only as updated as the information provided in the previous submission.
Mile-High Spitfire
RadioShack Pro-106 RadioShack Pro-652 RTL-SDR Unication G5 Uniden BCD436HP (On Loan)
MNN-250
Old 06-26-2018, 12:14 PM
I want to import these frequencies via Ez Scan: ULS License - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Conv License - WQYB434 - Pitkin County - Frequencies Summary
These frequencies are not listed on the State of Colorado DTRS link.
Moving forward, who would I contact to get the frequencies listed by Radio Reference removed and these new frequencies updated for Pitkin County?
Thanks.
Old 06-27-2018, 2:22 AM
You can make a submission to the database yourself if you have identified what they are being used for. I would read the RR Database Submission Guidelines before making any sort of submission. RadioReference does not accept frequency information based on FCC license information only. You can make the submission by going to the Pitkin County database page.
You will need to manually program the frequencies with EZ Scan until RadioReference gets good identified information about those frequencies and what they are used for,
Mile-High Spitfire
MNN-250
Old 06-27-2018, 5:26 PM
Are there any members of this forum who are in Pitkin County?
