El Paso County is at ASTRO-25 release 7.2. The State of Colorado is at ASTRO-25 release 6.5. How the system processes calls is exactly the same, but there are added features to release 7.2, such as the ability to have IP-based consoles, along with a lot of hardware changes (new zone controllers, routers, switches, etc.). Most of the software that is running on the system is exactly the same as earlier releases, with the new features added to them. If El Paso County programmed DTRS into their radios for the MAC talk groups, they would work just fine - as long as they were using DTRS sites, not the El Paso County system.
When El Paso County reprograms their radios, it will probably be in advance of connecting their system to DTRS (they have to in order to change the trunked system attributes to work when their system changes to D1C) - so the MAC talk groups will probably either be turned off, or turned on but don't work outside of their system until it is connected with the rest of DTRS. CCNC will have the funding for the jump-upgrade to ASTRO-25 release 7.2, most likely through DOLA grants.
