470/473 Mhz Base Antenna
ermin
Jacksonville Florida
Hello
Our CERT group is looking for a good omni antenna for 473 Mhz xmit and 470 Mhz receive. Don't need a lot of gain but it needs to be tough for our hurricane area. Right now we're looking at the DB411.
Any other suggestions? I need to keep the cost around the same as the DB411 please.
Thank you
Ermin
rescue161
KE4FHH
Hubert, NC
The 411s are tall. I second Chief21 on the 404. If you don't need any gain, then the DB201 is excellent. They are built like a tank. We're on the coast in a hurricane prone area and we have hundreds of 404s and 201s in use.
ermin
I need to meet with the city and see of we can get a simplex channel programmed into the equipment. Right now everything operates on a repeater only.
Thank you
Ed
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9900; en-US) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.746 Mobile Safari/534.11+)
If your having problems trying to get quotes for the wiscom stuff, give Sinclair Radio Labs a try. They are some pretty rock solid radios. 310-C4- internally cabled exposed dipole array. There is not much better on the market. A although not a true onmi, you will probably not really notice the difference.
WB5ITT
Beaumont, TX
You can get a DB404C from Tessco....or Hutton Communications....The DB411 is not omni (it has a directional pattern) ...if you want gain, you can also look at the DB408C...same price as the 411 but true omni and same height (8ft)...a 404 will be 3db less gain but also 1/2 the height...if you need one, I can order it
