I see Comtelco makes some, but they are only around 19" long, I'm looking for something a little longer, similar in length to my 1322.
Thanks, NZ0J
The 1322, being a half wave antenna, is giving you a pretty good mix of gain and bandwidth. While there are "gain" dual band antennas, they will have less useable bandwidth that what you are likely looking for.
So, while I understand you want the additional gain, you might need to give that up to get the wider bandwidth you desire. A general rule is:
As gain goes up, bandwidth goes down.
As bandwidth goes up, gain goes down.
A 1/4 wave antenna is going to give you better bandwidth that the higher gain models.
I've put my 1/4 wave VHF antenna on the analyzer at work and the bandwidth of a basic 1/4 wave is pretty impressive. I had 1.6:1 (or better) across 144MHz to 174MHz.
Also, a 1/4 wave VHF antenna is going to work at UHF frequencies. I used to use a simple 1/4 wave NMO whip for my dual band hammy radio with excellent results. The pattern for UHF gets a bit "odd", but it was never an issue. Certainly something you could try in your case.
