Question about GMRS attic antenna
AGC21980
Hello all, new to the site here!
I have a question in regards to an attic antenna for GMRS. I am obtaining my license and would like to install an attic monted antenna for a base station. The house is a rental and I am not allowed to install anything exterior, but did get the OK to use attic space. I only have maybe 4 feet or so of height right at the peak.
My question is, I have been reading up on antennas and antenna gain. Due to the height, I could only use what they call a unity gain fiberglass base staion antenna. A ham friend of mine suggested finding a large metal or aluminum plate, drill the center and install a 5bd UHF mobile radio antenna in the center, and install that in the attic thus giving me "gain".
What do you all think is the best route and best performer? A fiberglass base antenna or the mobile antenna idea?
Thanks in advance!!
ermin
Jacksonville Florida
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_1_4 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B350 Safari/8536.25)
Try this
http://www.rfparts.com/catalogsearch/result/?q=SVU4500SP1
73
Ed
retiredinsemo
I recommend an Arrow Dual Band J Pole antenna. It may not have the most gain, etc. but is very easy to install/remove. I used one for several months in an attic setting similar to yours with good results. Moreover, it's a rock solid product that give excellent SWR returns. There's several models available based on your frequency requirements.
Arrow Antennas JPole 2m 70cm Dual Band Repeater FM
WA0CBW
Shawnee Kansas (Kansas City)
Some antennas require a "ground plane" and some do not. A typical mobile antenna requires a ground plane to provide the other half of the antenna. A ground plane does not "add" gain to an antenna. Some base station antennas don't require a ground plane. Antenna gain is a function of the antenna design and may or may not require a ground plane. Gain in a mobile antenna is usually achieved by stacking 1/4, 1/2, or 5/8 wave elements on top of each other. Adding a metal ground plane under a mobile antenna would improve its effectiveness. A ground plane needs to be a minimum of a 1/4 wavelength. A base station antenna that uses multiple phased "trombone" or dipole elements doesn't require a ground plane. Gain in this type of antenna is achieved by the multiple phased elements.
cmdrwill
So Cali
The FG400x series are a overpriced fiberglass fixed antenna with 18 gauge steel wire with piss poor copper plating inside.
"5/8 wave stacked" .. who the hell are they kidding.
