Laird WPD136M6C-001 Tri-Band Antenna Questions
timkilbride
Linn Co Iowa
Anyone have any tricks on making some slight tuning adjustments? 144-148 SWR's are fine, 440-450 SWR's are 2.5:1 or higher through out the band. I loosened the set screws to adjust the whip up and down but there is not enough play to make any difference.
Also I noticed in the spring there is no wire running from the bottom of the spring to the top inside the spring, like I have noticed in other antenna's with springs. Maybe this antenna is suppose to be like that? I can't find much help online with this antenna.
Thanks for any input
Tim
flux4201
Unfortunately its manufactured for the commercial bands. Amateur use is not built into it. My antenna also does not have a wire inside the spring, which means its meant to be like that.
prcguy
This antenna covers amateur and commercial out of the box with no tuning. At some freqs the VSWR can be up to 2.5:1 on this model and that's just how it is. Make sure you have an adequate ground plane, otherwise use it and be happy.
prcguy
trentbob
W3BUX- Bucks County, PA
... just so you know... I bought one of those PCTEL tri band antennas with the real wide base... it's awful... picked up some on VHF high... was terrible on UHF and 800... I got rid of it fast...
