clr2
prcguy
The coil in a CLR2 was a round circuit board with a spiral wound, tapped inductor. If you run more than a couple of hundred watts part of the coil trace will burn up.
As WA0CBW mentioned check with an ohmmeter from the coax center pin to ground and it should show a short if the coil is intact. Same with the vertical element to ground, it should also show a short. If the coil burned up it should show an open or high resistance, if its burnt and turned to carbon like what I used to do to them.
prcguy
