What kind of antenna is this?
BlueDevil
WA
What kind or type of antenna is this?
Cheers,
Brandon
gewecke
Banned
Illinois
That appears to be a gamma tuned dipole. How long the radials are would tell you what band it would be for. I'm guessing vhf high. 73, n9zas
gewecke
Banned
Illinois
Yeah, it does but its hard to tell the length in the photo so who knows ... 73, n9zas
BlueDevil
WA
I will get the length of it and post the measurements on here.
prcguy
An SO-239 is .625" dia, so measuring the one in the picture on my computer screen and dividing by the length of half the element I come up with about 22" or 44" for the entire element. There is some distortion in the picture but that clearly makes it a VHF high band dipole and probably near 2m.
A dipole like this is usually from a 2-bay or 4-bay dipole array and rarely used by itself. I have both a tunable commercial and fixed frequency amateur Cushcraft dipole array and also a Maxrad and the construction of this one is different. It is made by one of the other lower tier mfrs and could be a Laird or Antenex.
prcguy
BlueDevil
WA
178Mhz is definitely higher than anything I would use. Be perfect if it was in the 155Mhz range!
NDRADIONUT
FARGO ND
You could easily make it a bit longer by adding some tubing on the ends 36" total length for 156.0000...
