Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Commercial Radio Antennas
Commercial Radio Antennas - Please keep discussion related to professional, commercially used antennas and antenna systems for the two-way radio industry. Topics for the use of these antennas on amateur bands are accepted here.
Old 04-10-2017, 5:46 PM
Default Tuning an antenna for 477MHz
Hi,
Our group is using the NA-771 antenna on Baofeng radios for the 477-478MHz Personal Radio band in my country. Would there be much of a performance increase if we cut these antenna for that band? Is there a way to work it out? or is there a better (and robust) solution to increase antenna performance on this band?
Thanks for your time.
Old 04-10-2017, 5:59 PM
riccom's Avatar
It is a dual band antenna, best bet is to get a mono band antenna for that
Sent from my LGLS676 using Tapatalk
Rd-5r pro-2062 bf-8hp beojie 218 bc335c and a partridge in a pear tree!
Old 04-10-2017, 6:21 PM
Any suggestions?
Old 04-10-2017, 6:40 PM
jonwienke's Avatar
First thing would be to check tuning with an antenna analyzer. They already work pretty well in that frequency range; cutting the antenna might not help. Also, google Nagoya 701C.
Old 04-10-2017, 6:42 PM
riccom's Avatar
Originally Posted by 5canhead View Post
Any suggestions?
Look at this on eBay http://www.ebay.com/itm/221779754800
This is a good start
Old 04-10-2017, 7:08 PM
Thanks, so the general consensus would be that im going to get better performance from a tuned UHF antenna vs a longer dual-band antenna like the NA-771? I don't understand radio theory too well but from what i can glean from the charts is that NA-701 would perform better on my frequency than NA-771 and that the NA-701C would be even better.
Thanks for your suggestions.
