Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Commercial Radio Antennas
Commercial Radio Antennas - Please keep discussion related to professional, commercially used antennas and antenna systems for the two-way radio industry. Topics for the use of these antennas on amateur bands are accepted here.
Old 04-23-2017, 12:33 PM
Default NOAA Alert - Kenwood NX
Hello, I think I have pretty well gotten a handle on the grip on the KPNG programming software for Kenwood NX-5000.
2 final questions:
1. In scan mode, how do I make it revert to chosen-channel where the rotary switch indicates?
2. Ive set up a bank with all NOAA alerts and want it to scan and break the audio at 1050Hz on the frequency that alerts.
Thank you so very much in advance!
Old 04-23-2017, 1:06 PM
Ok. I've got scan issued resolved. I created NOAA in scan mode. Now I just need to figure out how to silence until alert of 1050HZ open up the channel
Old 09-07-2017, 9:55 AM
Interesting subject... So if I am understanding your posts correctly you were able to get the radio to behave like one of those NOAA weather radios that use the "S.A.M.E." alert codes for specific types of weather conditions and cities and counties, is that correct? If yes, I have to say that I was not aware that a commercial radio was capable of supporting/decoding "S.A.M.E." code functionality, let alone opening the squelch when the 'attention' tone is received... Does the squelch close back up when they send the 'end' tone, like they do every Wednesday for their weekly test?
Doug
Old 09-07-2017, 10:33 AM
crazyboy's Avatar
Doug
It wouldn't be the same code, it would be utilizing the 1050hz tone only.
Old 09-07-2017, 10:36 AM
crazyboy's Avatar
2 final questions:
This is not going to work as you were hoping, the radio is going to get hung up on the first channel since it gas a constant carrier.
Old 09-07-2017, 11:28 AM
mmckenna's Avatar
If you set up the channel with the paging function, set both tones to 1000Hz, it'll work. It'll be muted until it hears the tone, then open for the amount of time that is set. It's very similar to setting up a channel with 2 tone paging, just make both A and B tones the same.
Old 09-07-2017, 12:23 PM
crazyboy's Avatar
Yes, but it is not going to scan all the weather channels for the tones. It's going to receive the one, with the speaker muted and then unmute that channel when the tone comes through.
Old 09-07-2017, 2:35 PM
mmckenna's Avatar
Correct, when it receives the 1005hz tone, it'll decode for as long as you set it to, up to 300 seconds, or reset time to "off".
The OP would need to have it start scanning again.
But to act as a simple weather alert receiver, it'll do the trick.
