Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Commercial Radio Antennas
Commercial Radio Antennas - Please keep discussion related to professional, commercially used antennas and antenna systems for the two-way radio industry. Topics for the use of these antennas on amateur bands are accepted here.
  #21 (permalink)
Old 05-30-2017, 6:51 PM
madrabbitt's Avatar
Originally Posted by mmckenna View Post
mmckenna's responses are pretty much "smart thing, smart thing, super knowledgeable thing, vhf phantoms are bad"
I've learned many things from him over the years, so thats totally a great place to start on your search.
Originally Posted by lu81fitter View Post
Just another thought.... If you were to contact an object with your 1/4 wave whip antenna that is hanging low enough to distort it and bend it over as to where it needs to be physically straightened out, it may completely destroy a phantom type antenna.
This is an excellent point. I've ripped a UHF phantom off the top of an ambulance in the past. damaged the mount as well as the fiberglass roof. Apparently the "max clearance" label in the cab was wrong. Totally forgot about it until now.
  #22 (permalink)
Old 05-30-2017, 7:06 PM
I agree with madrabbit. mmckenna is a very knowledgeable person here. I have learned from him an well. He is a valuable asset to the RadioReference community!
  #23 (permalink)
Old 05-30-2017, 8:03 PM
As has been said the use of 1/4 wave antennas on an ambulance is about the best choice you can make. the frequently go under overhangs that will tear normal antennas right off the roof.
i have worked with a number of the ambulance vendors in the past. Unfortunately, the walls are not made to be able to run radio remote cable in after they are installed. So you end up having to run them on the inside surface or under the counters where you can. The electrical feed to run the radios off of is just as bad.
Grounds in most ambulances is poor at best.
Getting back to the roof mounted antennas, I would suggest going with the Sti-Co models of their flex 1/4 wave antennas. I have met both the owner and her main design engineer. The flex antenna can be tied in a know and suffer no damage. You may pay more, but don't have to worry about the antenna hitting things like a low over head roof at a hospital or a tree branch.
If you don't like the suggestions people on the group here have provided, then do as you please. But don't come back crying about the antenna you put on the roof and it didn't hold up.
Jim
  #24 (permalink)
Old 05-30-2017, 8:04 PM
MCore25's Avatar
Don't think I've physically found an instance where it's not worth replacing a ~$10 antenna versus straightening a bent antenna.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you
  #25 (permalink)
Old 05-30-2017, 10:18 PM
RFI-EMI-GUY's Avatar
Nothing beats those NMO quarter waves. Put some spares in each rig!
"Have Spectrum Analyzer, - Will travel" "Going Green"
  #26 (permalink)
Old 05-30-2017, 10:20 PM
You might even want to leave a small bend at the base if its constantly hitting the same overhang!
  #27 (permalink)
Old 05-30-2017, 10:32 PM
mmckenna's Avatar
Yeah, cheap, easy to replace, and tilting them back a bit helps. You can also get them with spring bases, but I'm not convinced they are any better as it moves the bend point higher.
The other benefit is that 1/4 wave antennas are very broad banded.
A properly tuned 1/4 wave VHF antenna will safely cover the entire VHF high public safety band, federal band and down to 2 meters with ease. 2:1 SWR or below. While this may not seem important, interoperability channels (both federal and non federal) can be from 151 up to 170MHz. All your radio really should have all of the band specific interoperability channels programmed into them, without exception. Going with a higher gain antenna, like a 5/8th's wave, can run into issues.
UHF quarter waves are even more wide banded, easily covering the UHF band from federal well up towards T-Band.
  #28 (permalink)
Old 06-03-2017, 8:38 AM
Default Ambulance antennas
Originally Posted by kc1efx View Post
Good morning everyone!
I'm looking to see if the community can help me with some suggestions on decent NMO VHF and UHF antenna's to install on a new ambulance my department has acquired. We have 4 mounts center line of the box requiring two UHF and two VHF antennas.
Looking for high-quality products that are low profile and/or include a spring base (just like everyone else they tend to grab the door on the way out).
Considering Phantom antennas purely for that reason, however, I'm finding the consensus is they are junk.
Have been dealing with this ambulance problem of losing whips forever. Seems most of the older Fire Stations as well as the hospital emergency room back in areas have little to no clearance with the modular boxes getting bigger. Finally found a product that will stand up and will never have to be replaced.
A company called STI-CO Industries makes undercover applications for various vehicles and undercover cars that want nothing showing. A good example is a number plate frame!! buttt very pricey.
So I buy my parts from Tessco in Maryland, sure many of you have dealt with or heard of them. Stico makes a black quarterwave standard tad/mount Motorola uses. It is field tunable and comes in 136-1000mz. This antenna is made of an amazing material called Nitinol....I call it piano wire. You can litterly take the whip, tie it in a knot, untie it and it comes back to a straight whip! It will lay down flat with next to no clearance and pop back up again. These have proven to be perfect for the application, and cost $37 which is pricey for a quarterwave, but worth not having to check your roof on a daily basis to count how many antennas are left.
Also a good idea when the vehicles being built to favor the vhf antennas up front, seems the rear antennas take the brunt of the beating backing in the ramps at the hospitals. Hope this helps out, I know I for one haven't replaced a single ambulance antenna in a couple years. I do Motorola public safety radios for municipals.....
The exact model for this antenna is ROOF-FT=NITI-M.
Good luck
Last edited by lifeisgoodoneasystreet; 06-03-2017 at 8:41 AM.. Reason: missing model #
  #29 (permalink)
Old 06-04-2017, 5:35 AM
JFDoering's Avatar
Exclamation Fiberglass Roof: Caution!
If your rig has a non-metallic roof, you will need to add a ground plane under the antenna unless you install a "no ground plane" antenna designed for that application. No ground plane antennas, such as the Laird model B1322N for VHF hi-band, will be about three times longer than an 18" quarter-wave.
J.F. Doering Jr.
  #30 (permalink)
Old 06-04-2017, 2:37 PM
Correct. We ARE assuming the vehicle being new has the proper ground plane inside. Most coach companies that install the mounts per request of the purchaser are using a circular plate the size of the quarter wave. The kits are also available online if it's a do it yourself. On an ambulance with just fiberglass, a no ground plane antenna with a 3/4 tad mount will rip right out of the fiberglass. They also have a rather heavy duty spring which is not very forgiving when hit toward the bottom. Very little on the tabs holding it in there. Either way, a 3/8 style hole mount is better for the application no matter what you're using for an antenna.
The no ground plane antennas you refer to are half wave, so the cut will be about double, not 3 times longer. I just put one on a John Deer tractor, 156mz was about 31 inches. Still too much for the roof of an ambulance. Bottom line is do it right, have the dealer install the proper grounding, then use what you want.
  #31 (permalink)
Old 06-05-2017, 6:29 PM
best to use 1/4 wave whips
they give great performance and are extremely durable
