Laird WPD136M6C-001 Performance Woes
alcahuete
Antelope Acres, California
Just purchased this antenna and it arrived bright and early this morning.
I haven't had the chance to test SWR extensively yet, but it seems good in most places, and it is being used on an existing installation, that works great with other antennas.
This antenna has gotten a couple rave reviews here, and other places as well. I'm using it mainly for business band stuff, but with its broadband capabilities figured it would be nice to have 1 antenna for that plus ham frequencies as well.
After hooking it up this morning, this antenna is being SEVERELY outperformed everywhere by even the 1/4 wave whip that it was meant to replace. The performance difference is 2, sometimes 3 bars lower (XPR5550) on this antenna vs. the 1/4 wave.
Anybody have any clue as to what might be going on? It was brand new from Laird, not used or anything.
Any help would be greatly appreciated, since I'm just lost.
iMONITOR
Silent Key
S.E. Michigan
It's a unity gain antenna to begin with. Looking at the vague specifications, it doesn't really indicate what it's tuned for. I would not expect great performance for amateur radio or scanner use.
Hiding in a coffee shop.
I'd check to make sure the center pin of the antenna is making contact with the NMO mount. Some antennas can have a longer skirt on the base and prevent the center pin from making contact.
I'd also look at strong out of band signals. Could be the multiband antenna is picking up strong signals from nearby and impacting the receiver.
AI7PM
The Intermountain West
I've used one as a temporary replacement when and dual band fell apart. It had a flat VSWR across 2m and 70cm. I didn't notice any reduced receive.
iMONITOR
Silent Key
S.E. Michigan
I just bought a Laird 760-870 base loaded antenna. It's very high quality. The center pin in the NMO connector is gold plated, and has a strong spring loaded plunger to assure good contact. Maybe there are some cheap Chinese copies out there.
alcahuete
Thanks guys,
I'll give a new mount a try. I have a few mag mounts laying around. I can least use that to make sure they are mating properly.
Mine is exactly the same. I bought it from Tessco, so unless Tessco started marketing cheap Chinese knockoffs as Laird products lately, it's legit. ;) I see what mmckenna is saying. Even with the spring-loaded pin, the pin is not very long at all.
My measurements say that it "should" be mating up with my mount, but it's probably a game of millimeters.
Not sure what's in the base of those, but checking for contact with a multimeter would tell you a lot.
I've found this on a few other antennas, where low NMO mounts don't make contact with some antenna bases.
alcahuete
That's definitely what I'm leaning toward. I found 2 magnet mounts laying around (one is even a Laird mount, which you would think would work with the Laird antenna), but to be honest, they all appear to have the same size mount portion.
I'll give these other mounts a try later today and see what I can come up with.
iMONITOR
Silent Key
S.E. Michigan
You're is nothing like mine. According to the model number in your OP, this is what you have:
Laird Technologies - 136-174/380-520/760-870 MHz Antenna w/ Spring TESSCO SKU : 368700 Mfg Part #: WPD136M6C-001 Qty/UOM : 1 EACH UPC: 888063687006
https://www.tessco.com/products/displayProductInfo.do?sku=368700
Usually these 'one does all' wide band antennas to not perform anywhere as good as one that is tuned for a particular band.
alcahuete
I was referring to the spring loaded center pin. Yes, it is exactly the same in that regard.
That is generally true. But at the same time Laird is not one of the companies that usually lies about their gain. While I'm not necessarily expecting 6dBi on that broad of an antenna (though they do state that figure), I definitely expect it to perform better than a unity gain 1/4 wave, or at the very least, the same level.
I don't have the RSSI numbers in front of me right now, but 3 bars on the 5550 is a HUGE difference in signal.
iMONITOR
Silent Key
S.E. Michigan
The XPR5550 is not a wide band antenna. It is tuned to perform between 450-470 MHz and has a gain of 5.5 dB.
At that frequency the specs for your WPD136M6C-001 shows a gain of only 2.1 dBi. around that same frequency band of 450-470. Even the claimed gain in the 700/800 band is still only 6 dBi. dBi is not the same as dB.
If you're going for maximum performance on both the scanner and the ham radio, I'd recommend installing a second antenna. The one-does-all approach is always a compromise.
alcahuete
I'm not going to lie...I have absolutely NO idea what you're talking about. The XPR5550 is a Motorola radio, not an antenna.
Yes...I'm well aware of that. That's why I clearly put dBi in every single one of my posts.
Not once in any of my posts did I mention a scanner...anywhere.
In any event, mmckenna and others, it does appear that the mount is not high enough to make contact with the pin on the antenna. I used a magnet mount today that perhaps was very slightly longer on the NMO screw part, and I really tightened the antenna.
It does appear to be performing really well now. I haven't been able to test it completely yet, since I just put it on the new mount about 10 minutes ago, but so far I'm pretty impressed. In my limited testing, it does seem to be handily beating the 1/4 wave.
Mmckenna, I know you deal with this stuff a lot for work...is there any way to find out how long the mounts are without just spending the money and testing? My exiting NMO punched through the roof is actually a Laird mount...which apparently isn't long enough to work with this Laird antenna. Very convenient. :D
Thanks again for the help!
iMONITOR
Silent Key
S.E. Michigan
Well it may be hard to believe I was trying to help. I guess I got confused along the way.
I'm not familiar with Motorola radio models. When I did a Google search on XPR5550, this antenna came up:
https://www.amazon.com/Motorola-450-470mhz-Antenna-XPR5550-XPR4550/dp/B00UO1ET9I
When I did a Google search on Laird Technologies - 136-174/380-520/760-870, I found this:
https://www.zipscanners.com/vehicle-scanner-antenna-package.html
You should have stopped me at my first reply where I said: "I would not expect great performance for amateur radio or scanner use." Sorry I cluttered up your thread.
I don't know, but it would be helpful if the manufacturers would settle on something. I've run across this before.
I've never had this issue with any Larsen antennas, which is why I usually stick with them.
Also, making sure the mount is designed for the thickness of the material is important.
alcahuete
You didn't clutter up the thread at all, and I know you were trying to help. I was just SO confused by some of the stuff you were saying. :) I was at work for most of these posts just posting super fast during some breaks, so sorry if I sounded short. I REALLY appreciate you trying to help. No ill-will intended at all. Thank you for replying!
It seems to be figured out for the most part, though I'm going to head out in the car a little later and do some more very non-scientific signal tests. :D SWR tests will be done tommorrow across various frequencies. I think the mount fixed it.
Now I just wish there was some way of telling whether or not various NMO mounts will work with this antenna. If I do decide to go with this antenna vs. the 1/4 wave, my current NMO mount is going to have to be replaced, and there doesn't seem to be a way to measure the length of the damn things, without just buying them and trying them out.
alcahuete
Thank you Sir! Yeah, I have a bunch of Larsen stuff too, in fact the majority of my antennas. Unfortunately, they didn't really have anything comparable to this one that I could find.
Oh well...guess it will just be trial and error.
captainmax1
Florida Keys
Yeah, trial and error, unfortunately…
I'm probably going to need to spec out some of these multiband antennas for work in a year or two. I've avoided buying one for myself for a few years, but work is going to force me.
I may need to purchase a few different ones and give them a try. If I do, I'll try to remember to measure the base.
