Folks,
Today, we are turning off the "old" legacy Web service which allows applications to automatically download data from the database. We've had a newer "SOAP" based Web service in place for quite a while, however some versions of applications still are using the old method.
If you are running an older version of a Scanner Programming Software application, you might be affected.
This post should help guide you in the right direction in terms of upgrading so that you aren't affected.
Don Star with StarSoft has updated all of his applications, please see:
Win500: PSR-500, PSR-600, PRO-106, PRO-197 Scanner Software for Data Management, Monitoring, and Control
Butel's applications have been updated, please see:
RR changes
PSREdit
PSREdit - Configuration Editors for the new GRE line of scanners
Proscan
Proscan Already supports the latest Web service... see the following URL for possible updates that might be required:
ProScan
Freescan
See the following URL for updates:
ScanNow.org - The Home of FreeSCAN!
Bctool
Bctool hasn't been updated in over a year, so right now this application does not support the new Web service. We don't have any further information or details right now on this application.
I'll add further as we receive updates....
Again, make sure that you upgrade your software packages ASAP.
RR changes
PSREdit
Proscan
ProScan
Freescan
Bctool
