Hi all! I'v been scanning for may years and for the past two weeks CSP on both my Uniden 396T's locks up on Troops D & C and holds with static. Squelch is set to 3, and I use 800mhz antenna and have checked all settings and nothing has changed within the scanner. I have a Uniden 996xt but it isn't happening on it. I have the last updates available for both scanners. I would clear them but then would have to figure out how to manually program them since I have always cheated and uses software but just cant get USB to work anymore. Any thoughts on what could be causing this? Thanks in advance.
