- Joined
- May 26, 2016
- Messages
- 2
So after a lot of research and money saving, I think I am ready to buy myself a scanner, however, I am a bit confused about a couple of things:
1. Will the Uniden BCD325P2 scanner be able to listen to Wethersfield CT Police, Fire, and EMS, as well as Aetna Ambulance DIspatch and North Central CMED? (the Wethersfield page: https://www.radioreference.com/apps/db/?sid=8163)
2. Can the BCD325P2 be programmed through some software program on a computer such as Freescan? Wethersfield is a Simulcast system so I am not sure if this will make it harder to program.
3. Should I purchase an AC or DC adaptor for it?
4. Should I upgrade my antenna to the W-801 Regular Gainer with BNC or the Austin Condor with BNC both of which are offered by Scanner Master?
5. Will I need either a DMR Upgrade or ProVoice Upgrade to hear any of the above-mentioned systems?
6. Does anybody know what frequencies Aetna Ambulance is dispatched on?
Thank you in advance.
