Oh I have run Antenna Search, it found the 7 AM/SW towers in my back yard. heh, try listening to anything with a 50kw SW stations 1/2 mile away, but thats for another time.
Rude or not, you have been the one saying that I didn't know what I want. I do. All I was asking was if more than one county of ALREADY in your database published towers could show at on the same screen. I'm not asking for anything that isn't already there. You have done a great job with the database, the towers, emitters, antennas, whatever you want to call them are already there.
Someone put them there, somehow, someway. I was asking that if RR could not have them show up when you zoomed out on the map was instructions or how I could achieve that on my own, either with instructions or a link to a tutorial.
Can't get that here. No problem, I'll take my not knowing what I want, non RF knowledgeable self somewhere else where the ego's are not so big or easily bruised.
Okay, I will try this with numbers and maybe, just maybe you will understand. I will only consider your county, which is not what you asked for but I suspect it will illustrate my point. If you were to want to see the just the PS antennas in your county alone, just which one of the
922 of them did you want to see on the map? All of them, that is what apparently you seem to think we should generate, I am sure you will have no problem what-so-ever in determining which little map pin to click on. And if we allow you to zoom out to include the adjacent counties the problem will only be worse.
Wait...did the thought that you didn't want to see ALL of them, just certain ones, just flit through your mind? Well that is what I have been trying to point out, only
you know what
you want to see. Seeing all 922 of them, for your county alone, on a map does no one any good. Since you know what you want to see, click on the license that you want, look at the map and do your figuring.
BTW, you must think anyone reading your above quoted reply pretty dense if you think anyone is going to buy your story that you only got 7 returns on an antenna search and they were all AM or SW emitters. You are using the "antenna" result and not the "tower" result I assume, since the vast majority of all PS antennas are not mounted on towers owned by the PS entity; indeed I am willing to wager that the majority of all PS antennas are not mounted on towers at all but on other structures.
