The RadioReference.com Forums
-   Database Discussion Forum (https://forums.radioreference.com/database-discussion-forum/)
-   -   Display character length (https://forums.radioreference.com/database-discussion-forum/248987-display-character-length.html)
mancow 09-14-2012 11:39 AM
I would like to offer a suggestion that the display description field in the database be limited to 12 characters max. This would accommodate the GRE units that max out at 12 and still display nicely on Unidens. As it is now it becomes extremely frustrating to import a large system such as the MOSWIN system and half of the text is cut off.
GTR8000 09-14-2012 11:49 AM
Are you talking about the Alpha Tag or Description field, or some other field?
mancow 09-14-2012 11:58 AM
Alpha tag section
GTR8000 09-14-2012 12:06 PM
There is already a 12 character limit for alpha tags.
mancow 09-14-2012 12:14 PM
Ahhh I'm getting terms mixed up sorry. I meant the site name not the talkgroup alpha tags. If you notice as with this system Missouri Statewide Wireless Interoperable Network (MOSWIN) Trunking System, Statewide*, Missouri - Scanner Frequencies the sites have huge description fields. When they are imported you get at the most half of some of them so it appears something like
Ashland (Fut
loumaag 09-16-2012 7:29 AM
Yeah, I don't think that is going to happen. Alpha Tags make sense since it tells you who is talking on your radio, the site name is nice to know but not critical (most scanners don't even display it) to your monitoring. Yes, when using software it would be nice but since you are in interactive mode (you should be looking at the RR site) while importing stuff you can adjust the site name to whatever you fancy. For those scanners that are pre-programmed and updated via the manufacturer based on the DB, enough of the site name shows up so that you know where the signal is coming from, full on the HP-1 and 16 chars on GRE models.
For display purposes, in the database, more is better when it comes to site descriptions. Although, based on a donnybrook that took place recently in a California forum, one would have thought the world would come to an end if it wasn't done "just so". :roll:
RUSTY_SHACKAFORD 10-06-2012 1:37 PM
I have to agree with that but what I don't understand is why Abbreviations are used in the description line. ie. Frederick Md P25 system
HTML Code:
DEC    HEX    Mode        Alpha Tag        Description            Tag
5497  1579  D          FredCoDUSWM1    DUSWM1                  Public Works
5498  157a  D          FredCoDUSWM2    DUSWM2                  Public Works
5573  15c5  D          FredCiFCCA      FCCA                    Public Works
Can anyone tell me what DUSWM stands for? And how about FCCA, It could be Forestry Conservation Communications Association or Federal Court Clerks Association and from Wikki FCCA Public Safety System. You can see that someone could spend hours trying to understand what the Abbreviations are that the Database Admin has put in the description line.
1.description, verbal description(noun)
a statement that represents something in words
JoeyC 10-06-2012 1:46 PM
The Division of Utilities and Solid Waste Management
loumaag 10-06-2012 3:35 PM
Originally Posted by RUSTY_SHACKAFORD (Post 1832228)
... but what I don't understand is why Abbreviations are used in the description line. ie. Frederick Md P25 system
HTML Code:
Yeah, that doesn't make much sense to me either. :roll:
RUSTY_SHACKAFORD 10-06-2012 6:54 PM
Thanks JoeyC and loumaag.
ericcarlson 10-08-2012 10:43 PM
You should not normally see abbreviations in the description field. However, you will certainly see them when the abbreviation is submitted without its translation and we don't know what it means. If you have clarifications, please submit them so that we can clarify the entries.
mancow 10-08-2012 10:59 PM
That makes sense to me now. Thanks for the clarification. I hadn't thought about the HP-1 since I don't own one.
Jay911 10-09-2012 12:41 AM
Two comments about sites and how they are entered in the RRDB:
One - Can we please eliminate, for now and forever, "Confirmed LCN"? That tells you absolutely nothing about the geographic location of the site. One should be able to assume that it's confirmed LCN order, since RR only accepts confirmed data.
Two - IMO a little bit more care should be put into what a site's text field contains. More might be better, but when you put "Smithville - Zone A", "Smithville - Zone B", etc., which I have seen in some fashion in various places before, all you get on a 16-character display like on, say, a 396XT or a PSR500 is "Smithville - Zon" for both (all) of those sites. Makes it completely useless.
GTR8000 10-09-2012 12:55 AM
Well no, not quite. Right from the DB Admin Handbook:
Always indicate whether frequencies for an LCN-based system are confirmed or unconfirmed. Create separate sites within each system for confirmed LCNs and unconfirmed LCNs – never mix both in one site. If the system is a single-site system, then site 1 should be “Confirmed LCN” and site 2 should be “Unconfirmed LCN” (if applicable). If the system is a multi-site system, then indicate in the site notes whether or not the LCNs are confirmed for that site. Always be sure to remove any unconfirmed LCNs from an unconfirmed LCN site once the LCNs are confirmed.
There is a "Site Location" field in the extended site information where the geographic location can be noted, in addition to the geolocation data that should be associated with the site in the first place. If it's a single site for a system, how difficult is it really to figure out the geographic location to begin with?
