Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum - This forum is for questions about the database such as how to use it, layout or usability issues or suggestions for improvement. It is not for pointing out wrong information or getting help with programming.
Old 05-09-2017, 11:12 AM
Post Former Independent Cities in Virginia
The towns of Bedford and Clifton Forge no longer exist as independent cities in Virginia and are now part of their respective counties. Is it possible to remove Bedford and Clifton Forge cities and move their data into their counties?
Joe
Old 05-09-2017, 12:21 PM
The corresponding pages in the Wiki have been updated, so only the DB-side needs updating at this point.
Thanks for catching this.
73 QDP
Old 05-09-2017, 9:13 PM
Good evening Joe,
You might want to submit your suggested changes to the DB using the following "Submit" links:
Submit:Bedford City VA
Submit:Clifton Forge VA
This likely will get the requests into the hands of the DBA faster than this thread.
Hope this helps,
73 QDP
Old 05-10-2017, 6:18 AM
An admin can't remove or create jurisdictions. This would probably need to be addressed by Lindsay.
Old 05-10-2017, 7:49 AM
Originally Posted by QDP2012 View Post
Good evening Joe,
Hope this helps,
I tried this a while back with a change request for Bedford. The DBA was able to move the city agencies to the county, but did not remove the city of Bedford.
That was my assumption based on my experience above. Thanks for the confirmation.
Old 05-10-2017, 10:07 AM
wa8pyr's Avatar
Technischer Guru
Yes, it's a Lindsay fix. I've forwarded the info to him.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
Old 06-07-2017, 3:42 PM
blantonl's Avatar
Founder and CEO
I went ahead and got them removed.
Thanks,
Lindsay C. Blanton III
CEO - RadioReference.com / Broadcastify
Facebook: RadioReference | Broadcastify | Twitter: @RadioReference
Old 06-25-2017, 4:06 PM
dtscho's Avatar
Lindsay,
Bedford City is still showing on the Virginia clickable map, and the new Central Virginia Radio Communications System (P25) is showing as four counties, when it only resides in three jurisdictions. I believe the old Bedford City may be the reason the system is reporting as being in four counties.
https://www.radioreference.com/apps/db/?sid=9074
Thanks,
Dave
Old 08-03-2017, 1:17 PM
blantonl's Avatar
Founder and CEO
I can't really fix the map because they are predefined - however I've fixed the existing references to Bedford City.
Old 08-03-2017, 3:59 PM
dtscho's Avatar
Thank you, Lindsay.
Dave
Old 08-04-2017, 3:04 PM
kb4cvn's Avatar
Location: Nowhere near a paved road, away from the maddening world.
Thanks Lindsay.
Due to the economic situation of the past decade, a number of smaller Independent Cities in Virginia have decided to return to Town status from being an Independent City, with Bedford being reabsorbed into the County back in July 2013. The cost of maintaining a independent parallel government was simply too much.
I had wondered for years why our local trunked system (CVRCS Edacs) appeared a "4 Counties", and had discussed it with David. The [former] City of Bedford was being counted as a separate entity.
Mark C.
