I have a feeling that Troy and kma are likely right; they've been 'shoe horned' into the trunked areas to make sure the Uniden and Whistler downloads have them. If they don't include the amateur radio tab for each state in the downloads, they won't. That's a pretty ugly design oversight in my book.
No design oversight; the scanners pull the frequencies whether they're listed as Ham or not.
Where these things show up is dependent upon the System and Function tags. If it's Amateur Radio or Ham, a conventional frequency or trunked system shows up in the Amateur Radio section; if not, it's in the normal section. If the ham DMR frequencies are listed as conventional, their function tag still gets set to "Ham" and would still show up on the Ham Radio frequency page for a given county.
Also, that one system mentioned in the OP would translate into 260 individual conventional entries. Pretty inefficient both for the dB and for scanners that utilize the dB.
This is the primary reason we have them listed as "trunked." Scanning several dozen individual channels (all identical except for the talkgroup code) slows down scanning dramatically.
The secondary reason is for neatness and readability in the database; a listing of several dozen entries, all identical except for the talkgroup, is very wasteful of space in the database and pretty hard to read, too.
If the Single Frequency P25 setting in scanners works the same way as DMR Conventional Networked, we should certainly change those entries as well.
I suppose we could tinker around to figure out a way to describe these without using the word "trunked" but this was the easiest way to do it within the existing structure of the database, without making serious changes to the back end.
My biggest gripe about the ham DMR systems is the rather lackadaisical coordination between the various networks. DMR-MARC hates Brandmeister, the feeling is reciprocated, K4USD seems to be stuck in the middle somewhere, no one really cooperates for the greater good, and in the end you have the World Wide English talkgroup using Talkgroup 2 and Slot 1 on some repeaters, Talkgroup 2 and Slot 2 on others, and some other talkgroup/slot combination on still other repeaters. Throw in the fact that a dozen repeaters in the same city can all be broadcasting the same talkgroup at the same time (astonishing waste of spectrum especially in an emergency), and you've got a recipe for confusion. Dang things ought to coordinated by the state coordinating bodies just like frequencies; sure would make keeping the database neat and clean easier. . .
