cold weather fronts
jackj
NW Ohio
That would depend on the front. A sharp enough temperature change could cause a temperature inversion and that could cause the signal to be refracted back down toward the surface so that a system could be heard hundreds of miles away. Although this is quite common on VHF, this will NOT happen on 800 MHz with the majority of fronts.
N2ICV
Gloucester County FM29in
It does happen on 800MHz! I have heard Baltimore City and Connecticut State Police TRS's from here in Southern New Jersey.
http://forums.radioreference.com/ne...forum/248469-good-ducting-between-snj-va.html
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I have, in fact, heard stories about having to shut down parts of the Delaware system due to ducting across the water from NJ. Yes it doesn't happen that often, but it certainly does.
