A quick run down of available linking technologies in general...
Echolink
- Radio oriented
- Windows only software for "SysOp" mode
- Not able to link without access to the public internet and by going through their servers
- Public nodes often get numerous connections, referred to as drive-bys, with nothing said by the station. You end up hearing "Connecting..." and "Disconnecting..." messages in short order
- A majority of nodes are not set up properly with issues ranging from over/under-deviated audio to propagating all repeater output to connected stations including courtesy tones, IDs, announcements even when not using an over the air link to the system.
A couple of points here. thelinkbox and SvxLink exist as Sysop Node options for Linux and MacOS, and QTel (part of SvxLink: is an available client for those platforms, but it requires port forwarding to work. The "drive-by connects" can be dealt for the most part by limiting the stations that are allowed to connect; audio issues are a stickier issue, as that is something that most people don't bother fixing, especially the link audio issues you mentioned.
TeamSpeak
- Not radio oriented, no provisions for direct interfacing
- Separate out of band signaling required for PTT/COR, time lag between voice frames and control data not synced
- Ability to run independent of Internet on private LAN/WLAN
- Miscellaneous other features that might add value
- Multiple OS support
IRLP
- Proprietary radio oriented system, single source of hardware
- No connections allowed to/from other linking systems
- Internet dependent?
- Linux only
Asterisk
- Open-source PBX telephone system
- Several developers with amateur radio background
- Radio oriented module, app_rpt
- Ability to interface with equipment from simplex base up to full duplex repeater
- Can act as entire repeater controller
- Several interfacing options including DIY modified USB sound cards, commercially produced USB sound cards, and commercially produced boards
- Capability for voting and simulcasting radio networks
- Ability to link when one or more locations are behind a firewall such as cell-based mobile nodes
- No internet required
- On a single server both phone PBX and radio systems can run independently or with configurable interconnections
- Multiple network layouts are able to be used from single nodes on individual servers to multiple nodes on one server linked to several more on one or more additional servers
- Linux only
- Can connect to Echolink, capable of connecting to IRLP but that function was removed at the request of the IRLP owner
- You can be a part of the growing AllStarLink network
- The list goes on....
IRLP Experimental Nodes can be connected to AllStar Link via the rtp-dir channel driver, but the IRLP channel driver was removed as you mentioned.
I would suggest looking into Asterisk/app_rpt. There is somewhat of a learning curve, especially if you are new to Linux, but the possibilities really are endless.
I tried to cover everything but I appologize if a missed something.
Hope that helps you be more informed.
I added my 3 cents; and if anyone wants to get in touch with me via Radio over IP, I can be reached at Echolink Node 749507, AllStar Link node 28913 or D-STAR DExtra Reflector XRF669 A.
