Go Back   The RadioReference.com Forums > Amateur Radio > Digital Voice for Amateur Use
Digital Voice for Amateur Use - Discuss use of digital voice technologies on the amateur radio bands. This is to include technologies such as VoIP, P25, DMR/TRBO, NXDN, D-STAR, etc.
  #21 (permalink)
Old 03-25-2015, 8:32 PM
Default More Fusion online
In Chattanooga, Tn 444.100 is now a Fusion site. It's in close proximity to the 146.790 machine, which has been Fusion for a while. Word has it another Fusion site going up in Dalton, Ga very soon, giving areas south of Chattanooga coverage. Stay tuned.
BG..
ButchGone
  #22 (permalink)
Old 04-04-2015, 12:06 PM
Jay911's Avatar
Originally Posted by robertmac View Post
In the Calgary, Alberta area, the following repeaters are reported to have Fusion ability:
145.1100 VE6EIT Bragg Creek [analog as well]
146.6850 VE6CID
146.940 VE6RPT Cochrane analog and P25? [have heard digital on here but also may have been P25]
147.000 VE6HRA Alderysyde [have heard digital on this frequency] and analog
147.135 VE6GER Crossfield analog but is currently listed as Off-Air
444.000 VE6RYC [but not 146.85 which is also VE6RYC] analog as well
444.675 VE6FIL [have heard digital signal on this frequency] digital only
Other repeaters listed as having Fusion in Alberta
Medicine Hat frequency posted above
442.175 VA6ARD Red Deer/Pine Lake area.
EIT is not yet online but should be dual modulation when it is. I'm meeting with the repeater owner today.
RPT's VHF side is Fusion. The only P25 repeater I'm aware of in southern Alberta is RPT's UHF side (444.9 $293).
  #23 (permalink)
Old 04-29-2015, 2:48 PM
Default System Fusion
The Batesville Area Radio Club in Batesville, Arkansas is proud to announce that the 147.270 machine, located on Brock Mountain is now System Fusion running in AMS mode. With a PL of 94.8 and a CTCSS of the same, analog users will still be able to use this machine. Please include the CTCSS in your programming so your receiver will "skip" the digital audio if scanning. Also, the use of the monitor function and the visual check of your "busy" light will let the user know if the channel is clear BEFORE transmitting.
Applications have also been made to replace the 444.750 machine. Future plans of WIRES-X are being discussed.
Also, another local frequency, 147.225 has recently took a lightning strike. Application has been submitted for a System Fusion replacement for this machine also. This is linked with IRLP node 3956, and will be back online soon.
Questions on this system can be directed to:
Noel Seeley K5NES
noeleo@suddenlink.net
  #24 (permalink)
Old 05-13-2015, 9:10 AM
911dispatcher's Avatar
Default System Fusion repeater in Rochester, IN On The Air
System Fusion is running on the KB9WSL repeater in Rochester, IN (Fulton County)
146.805 (-)
131.8 CTCSS transmit and receive
AMS ( IN) Analog FM (OUT)
  #25 (permalink)
Old 06-13-2015, 2:45 PM
wkm wkm is offline
WA7LAW Everett, WA
147.180 (+) 103.5
447.575 (+) 103.5
Currently offline scheduled to be online 6/14. They installing a new tower with the fusion repeater.
The remote receiver is operational at 147.180 127.3 running in simplex.
  #26 (permalink)
Old 07-17-2015, 11:01 AM
VO1NTV
444.600 (100.0) - St. John's , NL , Canada
Matt.
Broadcast Engineer , Ham, radio collector.
  #27 (permalink)
Old 07-29-2015, 2:54 AM
145.210 Knoxville W4BBB, 147.000 Sevier KD4CWB
Sent from my SM-S765C using Tapatalk
  #28 (permalink)
Old 09-14-2015, 6:24 PM
Dallas has two now...
From the Dallas Amateur Radio Club W5FC
Band - 70cm
Analog Frequency - 442.425 *
Input Frequency - 447.425
PL ToneIN/OUT - 110.9 / 110.9
* The 442.425 MHz Repeater is a Yaesu™ System Fusion (PDF) machine.
AND
Also the 146.96 PL 110.9 Dallas REACT System Fusion repeater has also been installed this week. So Dallas now has 2 fusion repeaters with good coverage.
  #29 (permalink)
Old 09-16-2015, 10:51 AM
N9PBD's Avatar
The Midwest VOIP Users ARC in Swansea, Illinois is operating KC9WKE, a DR-1X on 444.175+ 79.7 in Auto/FM mode.
The repeater is linked to ALLSTAR (node 27915), ECHOLINK (node 429456), IRLP (node 8996) and Yaesu WIRES (room 21017) VOIP systems.
KC9WKE - Callsign Lookup by QRZ.COM
Greg, N9PBD / WQVW265 TM-D710GA, FTM-400DR, FTM-100DR, FT1DR, DR-1X (MMDVM), CS108G, CS750, CS800D, BCD536HP, BCD436HP, TRX-2, BCD396T, BC796D, BC785D, BC780XLT(x2), IC-7300, IC-718, IC-R75, IC-R7000
  #30 (permalink)
Old 10-22-2015, 3:45 PM
Noel Seeley K5NES
UPDATE:
Batesville 147.270+94.8 ACTIVE YSF in AMS
Batesville 444.750+94.8 ACTIVE YSF in AMS
Batesville 147.225+107.2 ACTIVE YSF in AMS IRLP 3956, ECHOLINK 506198
If you're in the area, please utilize these repeaters. ID and wave a hand to say HI.
Noel
  #31 (permalink)
Old 10-22-2015, 5:52 PM
In my travels I've been on several Fusion repeaters. Only once was the person on the other side using the digital side.
Seems a lot of Fusion machines going up, are going up because clubs can get them at $500 and reasonably replace their old equipment. They are using them as analog replacements, vs wanting to add Fusion. (So I've been told in these conversations)
Anyone else seeing that?
  #32 (permalink)
Old 10-24-2015, 4:34 PM
My club (Mississauga ARC) recently put the first of their two new Fusion repeaters on the air: 444.575 (+) 103.5 in mixed mode operation. We took advantage of the Yaesu deal (brilliant marketing!) and bought two to ultimately replace our two aging GE Mastr II's.
I don't have a Fusion radio to test digital but for analog comms the audio sounds fine. And we've set ours to transmit PL on analog only so that those users without Fusion gear won't be bothered by the digital noise.
  #33 (permalink)
Old 10-25-2015, 11:42 AM
Default West Central WI Fusion
In Wisconsin (West Central) along I94 corridor in St Croix County (from MN border to Mile Marker 31):
Hudson, WI (Mile Marker 1 - 4 area) FUSION ON-LINE SOON (Repeater is in burn in)
145.1300 - 0.600 Mhz PL 110.9 Hz Encode/Decode AMS-In/AMS-Out
Roberts, WI (Mile Marker 10)
147.3300 + 0.600 Mhz PL 110.9 Hz Encode/Decode AMS-In/AMS-Out
Covers most of St Croix County and into St Paul, MN/East Suburbs
Baldwin, WI (Mile Marker 19)
442.2250 + 5.0 Mhz PL 110.9 Hz Encode/Decode AMS-In/AMS-Out
Currently in beat testing until new housing at Tower site is built, currently rebroadcast Roberts 147.3300 so input (447.2250) is offline.
- I am working towards a network where all digital modes and analog will work together...and we are on the way!
- Remember if it is transmitted, it can be heard!
  #34 (permalink)
Old 12-05-2015, 1:49 AM
robertmac's Avatar
Just an update on Fusion repeaters in the Calgary area. The Fusion repeater was removed from 444.000 and replaced with DMR [and I am still trying to like digital but find that DMR, to me, is not as good as what I could hear on the Fusion repeaters-far too nasally or monotone]. The 146.94 had a problem with the Fusion repeater and was removed. It is P25 but do not monitor it and I think the only ones using it are the people that installed it. 444.675 is still Fusion and is used by a few people.
  #35 (permalink)
Old 01-10-2016, 11:55 PM
N9PBD's Avatar
Shiloh, IL FUSION ON-LINE SOON (Repeater is in testing)
(AA9RT) 444.300+ 5.000 Mhz PL 123.7 Hz Encode/Decode AMS-In/AMS-Out
  #36 (permalink)
Old 01-13-2016, 2:13 PM
wb0wao's Avatar
Scopus, MO (20 miles west of Cape Girardeau, MO)
W0QMF 146.820 PL 100.0 operating in AMS mode
Cape Girardeau, MO
W0QMF 146.685 PL 100.0 currently operating in analog mode, but will be switching to AMS within a month or two.
BCD996P2/BCD325P2/PSR-410/WS1098
Cape Girardeau Area Monitoring Blog
capescan.blogspot.com
GMRS -- WQWR852
  #37 (permalink)
Old 01-14-2016, 8:48 PM
N9PBD's Avatar
The AA9RT 444.300+ Fusion repeater is now on the air in AMS/AMS mode. We'll be making some more system upgrades in the near future, and plan on a Wires-X interface, and future linking to another Fusion repeater northeast of here.
  #38 (permalink)
Old 01-15-2016, 9:11 PM
Thumbs up Yaesu fusion repeaters
N5SEA has two, both are near Monticello AR.
147.210 and 444.825 "CTCSS" 127.3
  #39 (permalink)
Old 01-15-2016, 9:57 PM
Tulsa Amateur Radio Club went on the air this afternoon (1/15) in dual-mode on 145.110, PL 88.5 from the site on Lookout Mountain @ KTUL Channel 8. Initial and testing reports in both analog and C4FM are good. No WIRES Internet connection at this time.
  #40 (permalink)
Old 04-02-2016, 3:35 PM
Default Cental California Fusion
Hello all,
443.800 + PL 114.8 Hz is now on the air in the central San Joaquin valley. It is running in AMS mode. Callsign is KE6JZ. Located in Fresno. coverage is from about Modesto to Delano/ I-5 and SR/99. No WIRES connection as yet. All are welcome !
73,
Shane Ke6jz
