Go Back   The RadioReference.com Forums > Amateur Radio > Digital Voice for Amateur Use
Digital Voice for Amateur Use - Discuss use of digital voice technologies on the amateur radio bands. This is to include technologies such as VoIP, P25, DMR/TRBO, NXDN, D-STAR, etc.
Old 06-08-2017, 4:04 PM
teufler's Avatar
Default Don't know what I am doing
Trying to get the DMR database into my tyt 390. Just want to display contacts name and location rather than a number. I have the latest 380 tools loaded, and went to NOGSG Contact Mgr and imported up to 1000 into the 390 code plug. Then into 380 tools and accessed SHOW CALLS, AND nothing. Did the same on the cs 800 and it works, but the 390 ,. can't get it to work
WD0GSYDMR ID 3129226 AND 3129304
BC-396XT,780XLT,TENTEC PARAGON, TYT-2017, MD-390, DM-5R+, ANYTONE 5888,VX10, VX7, VX3,TERMN-8R, F8-HP, GT3, UV-5, UV-3R, WOUXUN UV-8D,JUENTAI UV8DR,
Old 06-08-2017, 4:15 PM
The only way you'll be able to get that database into your unit is by flashing it via the Travis Goodspeed method. If you are using Windows, then you will need to virtual machine into it. It's EXTREMELY easy, as long as you read the directions.
I'm going to find you the directions as to which method I used. Setting it up will take you about 15 mins. Then in the future, when you want to update the user database, that'll take you 5 mins.
Old 06-08-2017, 4:41 PM
teufler's Avatar
ok, I was hoping it was as easy as the cs800.
Old 06-08-2017, 5:32 PM
These are the instructions that I followed in order to get the newest MD 380 Tools along with Flashing the DMARC user list. This method is directly tied to Travis Goodspeed's project. At this time, this will work on all flavors of the MD 380, 390, Retevis with or without GPS..
Update your MD-380 / Retevis RT3 or MD-390 with GPS / Retevis RT8 with GPS from
Windows running a Linux Virtual Machine
By: Warren Merkel, KD4Z
Version 3.08
The 2 Pictures I have attached are the screenshots you will be seeing and using. You will understand what to do in the instructions. The RECIPE commands are whats needed to make the process work.
For my 380, I did...
glv
glvusers
flash
finally....flashdb
Its THAT SIMPLE....Every so often, Ill update the DMARC user CSV by only using the following RECIPE...
glvusers
flashdb
Thats IT!
Disclaimer: You MUST follow the instructions step by step on how to load the virtual client to the computer and then follow the APPROPRIATE "Recipe" listed. Like I said, its extremely easy. If you can read, you can do this!
Old 06-08-2017, 5:39 PM
This video is some of the things that you are able to do with the firmware. In my opinion and usage, this is the must have to all the 380/390s out there.
https://youtu.be/1CHz33Db4-Q
