Go Back   The RadioReference.com Forums > Amateur Radio > Digital Voice for Amateur Use
Digital Voice for Amateur Use - Discuss use of digital voice technologies on the amateur radio bands. This is to include technologies such as VoIP, P25, DMR/TRBO, NXDN, D-STAR, etc.
Old 02-02-2018, 9:25 PM
Bubbarx's Avatar
Default DMR Trouble
Hello all,
I have a TYT MD-2017. It is functioning on analog just fine, but I am having trouble with the digital side. As far as I understand, the correct repeater slot, color code, frequencies, talk-groups for the NJTRBO Martinsville repeater are programmed into my radio. I did it myself as I couldn't get the old 380 code-plug they have working in the newer software they have to program the radio, but I have gone over it repeatedly and can't find an issue with my programming. Not sure if there is something I'm missing.
So the issue I'm having is that for the Martinsville repeater, I have the talk groups I want programmed in, I have parrot and audio test programmed, etc. I have can see the radio indicate that it is receiving audio on these channels, and the receive LED on the top goes green like it is receiving, but I am not actually hearing anything. It does allow me to key up on the system talk groups I have programmed in, but being able to key up is kind of useless if I can't hear the audio. I cannot for the life of me figure out what the issue is.
If you have any advice to offer on this issue, please let me know. (No I can't get a Motorola, I wish :P)
Here is a link to the website I used to get my repeater information:
https://www.n2jti.net/
Old 02-03-2018, 10:49 AM
Originally Posted by Bubbarx View Post
Hello all,
Do you have a receive group set? Some radios, including the MD-380 do not require a receive group to be set and they will work fine. On the other hand, some radios will not receive any audio if you do not have a receive group programmed. I don't own an MD-2017, but it's something to try.
Old 02-03-2018, 2:14 PM
teufler's Avatar
Default try this
Try this.
File Type: zip Mid-Atlantic MD-380U Codeplug v1.7test.zip (19.8 KB, 35 views)
WD0GSYDMR ID 3129226 AND 3129304
BC-396XT,780XLT,TENTEC PARAGON, TYT-2017, MD-390, DM-5R+, ANYTONE 5888,VX10, VX7, VX3,TERMN-8R, F8-HP, GT3, UV-5, UV-3R, WOUXUN UV-8D,JUENTAI UV8DR,
Old 02-03-2018, 3:13 PM
Bubbarx's Avatar
Originally Posted by teufler View Post
Try this.
Interesting, I wasn't able to get the other codeplug they had to work for some reason in the 2017 version of TYT's CPS, but this one did load up.
I still have that issue though. I can key up but no audio no matter what talk-group I try.
Same thing when I try it on other repeaters too.
Callsigns: Amateur KD2NWH // GMRS WRAF217
2x Motorola MTS2000 // Motorola MCS2000 // 2x Baofeng UV-82 // TYT MD-2017 // Uniden BCD436HP
Old 02-03-2018, 3:35 PM
Bubbarx's Avatar
I just tried this, it didn't seem to help unfortunately.
Try this.
Old 02-03-2018, 4:24 PM
Have you verified it is not a speaker problem? Can you hear tones/noise from the radio on power up? Have you tried an earpiece? TT
Old 02-03-2018, 4:26 PM
Bubbarx's Avatar
Yes, tones are all audible, I can hear the key up tone just fine, and it works well on analog channels.
Old 02-03-2018, 4:52 PM
Default dmr trouble
Had a similar issue this week ., programming an Alliance HD1
Solution was the admit criteria., we needed to use color code !
Just a thought
jerry VE3EXT
Old 02-03-2018, 4:59 PM
Bubbarx's Avatar
Just a thought
jerry VE3EXT
That is what I thought it was at first, but I have tried multiple repeaters and made sure I had the right color code for each and I haven't been able to get the digital audio. It is really frustrating.
Although in the past I was using my own manual programming, I'm currently using the code-plug provided on the repeater system's (NJTRBO) website, and still am not getting anything.
Old 02-03-2018, 6:35 PM
Default DMR trouble
I'm not talking about color codes but rather the "admit criteria"
some of the choices are always
color code
Find that area and play., see if any difference.
Jerry VE3EXT
Old 02-03-2018, 6:36 PM
Bubbarx's Avatar
color code
Jerry VE3EXT
Yeah the admit criteria is set to color code, I suppose I could try to see if setting it to something else helps.
Old 02-03-2018, 9:43 PM
Bubbarx's Avatar
color code
Jerry VE3EXT
Okay I gave changing the admit criteria a shot on every other option there was but still no luck.
Old 02-04-2018, 9:01 AM
W2PDX's Avatar
Is your digital contact (talk group number) set-up as a Group Call not a Private Call? If the radio is receiving a signal properly, which it sounds like it is, but not passing audio, then there is something incorrect re: the digital contact.
Old 02-04-2018, 6:10 PM
Bubbarx's Avatar
Yeah there are three options, Group Call, All Call, and Private Call, I have it set to Group Call.
There is also an option for Call Tone, not sure what that does, but its set to off.
Something weird happened today. I heard someone key up on North America for a split second and the little phone thing popped up to indicate it was actually receiving a digital transmission. Haven't heard anything since. I've tried other channels but nothing, in a month of messing around with this thing that's the first time I've heard anything. But I haven't heard anything on North America after that, so I have no idea why I heard that random transmission and nothing else.
Old 02-04-2018, 8:25 PM
Bubbarx's Avatar
Okay guys, so I'm not sure what changed, but I'm receiving SOME audio on NJ-NY Metro. However, it is coming in a bit garbled and incomplete, I am not hearing full transmissions and it is hard to discern what they are saying. Any ideas?
Old 02-05-2018, 8:05 AM
chief21's Avatar
It almost sounds as if you're not receiving a digital signal that is strong enough. Are you close to the repeater? Have you received this repeater previously? It's possible that your radio is seeing the signal from the repeater, but the signal may not be strong enough to actually recover the digital audio (garbled / incomplete). Depending on conditions (or your location in the building), sometimes it may work but mostly it doesn't.
Take your 2017 for a short road trip (closer to the repeater) and see if that helps.
John AC4JK
Old 02-05-2018, 4:55 PM
Everyone in NY and NJ sounds like that, try talking a republican.
jay thompson / CETsr, GROL
COML, COMT trainee
KC9VTT / COML DMAT CA-4
you must be really bored to be reading this far down
Old 02-16-2018, 6:57 AM
Do you have all your receive set to private instead of group?
Sent from my SM-S920L using Tapatalk
Old 02-16-2018, 7:41 AM
n9mxq's Avatar
If set to private, only the same DMR ID can use the spot. If public, any ID can use it.
Sent from my SM-G950U using Tapatalk
Gene
Transceivers, receivers, and SDR! Oh My!
Old 08-12-2018, 6:27 PM
Default MD-2017
Did you ever get this issue resolved? I am having a similar issue with my 2017.
