wa4htz
I know this has come up before and the solution seemed to be V1.16 of the 2017 CPS. I have a code plug for the 380 but when I open it in the 2017 V1.22 CPS, only some of the data in the code plug shows up. For instance, the contact list is completely blank. The nodes are all listed but there is no information under them. The scan lists are the same way, although with no contacts, I can understand why this happens. When I open the code plug in V1.30 of the 380 CPS, all fields are fully populated.
Does anyone know if the conversion function was removed from the 2017 CPS in later versions? Is there something about the 380 code plug I have which prevents it from being fully converted? Any help would be greatly appreciated as I am pretty much stuck at this point. I really don't want to have to enter this by hand. My typing is slower than sludge.
The code plug is for the PRN network (Carolinas and some repeaters in surrounding states), PRN – A Wide-Area Digital Amateur Radio Network.
Thanks in advance for any help anyone can give.
Ken
Ken
