Go Back   The RadioReference.com Forums > Amateur Radio > Digital Voice for Amateur Use
Digital Voice for Amateur Use - Discuss use of digital voice technologies on the amateur radio bands. This is to include technologies such as VoIP, P25, DMR/TRBO, NXDN, D-STAR, etc.
Old 06-15-2018, 1:08 AM
Default MD380 with zumspot - no rx audio
I set up a sunspot with my mdr380. Local repeaters are out of reach so I have never been able to verify the raidio works. I have set up several channels and one of them is BM TG 4000. I can see where my radio transmits on this talkgoup and using the pi-star dashboard it looks like a response come in on TG9.
No matter what I do I can't receive any signal on my MD 380. I set the side buttons to enable monitor mode but when I use them no static is heard. Its like my radio is muted. Any thoughts?
Old 06-15-2018, 1:30 AM
Is your squelch set to high?
Sent from my SM-T810 using Tapatalk
Old 06-15-2018, 9:01 AM
only two settings and I have tried them both.
Old 06-15-2018, 9:09 AM
n9mxq's Avatar
4000 drops all talkgroups from the reflectors. To use Brandmeister you just use the TG like you would with a repeater.
Sent from my SM-G950U using Tapatalk
Gene
Transceivers, receivers, and SDR! Oh My!
Old 06-15-2018, 9:15 AM
I have read that 4000 will send back some sort of robot voice saying disconnected. I can see in my zumspot dashboard that 4000 appears to reply and when listening on another radio i can here the digital sound coming from the zumspot. The md380 shows reception bars but no audio.
Old 06-15-2018, 9:17 AM
n9mxq's Avatar
Most likely its responding on tg9.. as you have observed.
Gene
Old 06-15-2018, 10:45 AM
Yes i think thats correct. Are there any talk groups where i could test the radio? I have tried talking in several groups but i have never heard any response. Not sure if no one is on or if i have a misconfiguration
Old 06-15-2018, 10:50 AM
dcr_inc's Avatar
set up a private call to TG 9990.. This is the Parrot and will transmit back to you what ever you say once you key up..
Just like a parrot..
Unications G5 Phase II (2), HP 1, WS1080 (2), PSR600, PSR500, PRO106, Commercial FCC license, Ham General, FAA Private Pilot, Business Owner, APCO Certified Tech.
Old 06-15-2018, 10:53 AM
Thank you i will try that tonight
Old 06-15-2018, 11:09 AM
n9mxq's Avatar
310 311.. take your pick.. 310 is almost always busy..
Gene
Old 06-15-2018, 11:28 AM
Those are the tac groups right? What does tac stand for?
Also do i have to keep up and identify in those groups in order to hear audio? I assume thats the only way the zumspot would know to switch to that contact and start transmitting audio?
Old 06-15-2018, 11:30 AM
n9mxq's Avatar
Tactical.. but nobody uses them that way.. 310 can be a cesspool of clicks and hotspot loops, but it's a great place to make sure your radio gears your spot as it's almost always busy
Gene
Old 06-15-2018, 11:57 AM
Delradio I'm monitoring BM TG 31374 for the next bit if you need someone to test with. Ki4anz Clay
Old 06-15-2018, 12:39 PM
chief21's Avatar
Regarding your Zumspot responding on TG9... is TG9 in your RX list on the MD380? If you're only listening on TG4000, you won't hear any response on TG9.
Old 06-16-2018, 8:13 AM
Thanks for all of the help guys. I programmed some of the channels you suggested and I was able to hear audio and even joined a TN net last night. I did have a couple of questions about DMR in general.
I identified on TAC310 and heard a conversation. I changed the channels on my radio but my radio kept going back to the conversation on 310. Is this something I set by accident? Maybe monitoring on my radio?
Also it seems like to get my zumspot to switch to a new channel I have to transmit on that channel which is possibly interrupting someone else. Is this the case ?
Old 06-16-2018, 9:07 AM
n9mxq's Avatar
Yes it is the case with most hotspots. Until you tell the spot (by keying your ht) that you moved to a different talkgroup.. it has no way of knowing you did so. They can, unless duplex, only run one talkgroup at a time.
Gene
