No specific questions yet, I'm sure I'll have some later! I've got a TYT MD-UV 380 coming. Looks like it's a decent radio for a good price - time will tell.
I did a *lot* of reading on DMR, hotspots and codeplugs before jumping in. I bought a Chinese clone of a ZumSpot in June and ordered a radio after the hotspot arrived. My UV380 bought in July seems to be a good radio. The receiver is sensitive and I am getting good audio reports. I bought a second battery as the charger takes 6-8 hours to fully charge the battery; no rapid charger here. I have been thinking about posting some UV380 crib notes on my website --
Amateur Radio -- as I seemed to be the only one with the new dual version, but I haven't done so yet. So perhaps the's incomplete thoughts may help...
1. When opening your new radio and loading the TYT CPS software, the very *first* to do is READ the radio, and save the initial file elsewhere as a 'do not touch' safety valve backup just in case. I name files in the the format of 'uv380-yyyymmddhhmm.rdt' so I can revert to previous versions
2. An MD380 codeplug will *not* directly load into a UV380. Let's leave it at that. If no one gives you an beginning UV380 codeplug, in my opinion the easiest solution is to use the
N0GSG DMR Contact Manager Support Page that can read in an MD380 codeplug and write it out in the UV380 format. You still need the TYT CPS software to read from and write to the radio.
3. The dual VFOs are not ganged. When one has UHF repeaters and VHF repeaters in the same zone list, you can listen to traffic on both receivers simultaneously. It is a nice feature. A few days later I discovered that VFO A audio has priority over VFO B if both receivers are active.
4. The UV380 has 3 power levels -- H, M, L - despite some comfusing literature. I tend to have a quick button program to change same. I program repeaters at M and step to H if needed. Use one of the buttons on the left side of the radio.
5. I might be able to share a codeplug with you but we have Brandemeister TGs and no C-Bridge installed yet.I am in an area where DMR repeater coverage is lacking.
At this hour I know I have not covered my notes, but it is a start... and it is late. Good luck. HTH.
