Anyone had problems using the SCHEART codeplug for the MD380
My radio will not accept the downloaded codeplug
New radio, maybe firmware incompatibility??
Cliff
That SCHEART MD380 codeplug is more than a year old.
Nevertheless, are you using an MD-380 or an MD-UV380 radio? The MD-UV380 will not read an MD-380 codeplug.
I would use the N0GSG Contact Manager -- N0GSG DMR Contact Manager Support Page -- to see if it opens the SCHEART codeplug without errors. The software can convert an MD-380 file to a MD-UV380 format if that is required.
Hi, Thanks.
I'm using a UHF 380.
I tried the N0GSG, without success, but have not had a chance to re-visit that route.
Thanks for the reply, 73's.
Cliff
My experience is the N0GSG sw will show codeplug programming errors not apparent when viewed in the TYT sw.
A trick I use with N0GSG at times is to first open a small (perhaps a half dozen entries) "good" codeplug and then append the questionable (or converted) codeplug. Assuming it seems to mash together, I will then load it into the radio with the TYT software to test.
New to this DMR game this summer, I found the N0GSG read-me PDF to be quite helpful for the subtle not-so-obvious features.
