FBI Chicago
rbrtklamp2
Dupage County, Illinois
I have been going through my notes and this is what i have for the FBI in Chicago, IL. If any body has any frequencies or info i missed please let me know.
Thanks,
Bob
0167.5625 1.FBI NATIONWIDE Off 167.9
0170.7250 FBI A-2/A-3 Off 167.9
0170.6250 FBI A-5/A-6/C-6 Off 167.9
0168.7250 FBI A-7 Off 167.9
0167.2125 FBI B-1/B-2 Off 167.9
0170.9000 FBI B-7/B-8 Off 167.9
0167.3375 FBI C-1 Off 167.9
0173.1500 FBI C-3 Off 167.9
0170.3500 FBI C-7 Off 167.9
0164.5500 FBI D-1/D-2 Off 167.9
0166.4625 FBI D-3 Off 167.9
0167.5375 FBI D-5/D-6 Off NAC 167
0163.1000 FBI D-7 Off NAC 167
0167.2875 FBI E-3/E-4 Off 167.9
0167.5125 FBI F-7 Off 167.9
0170.5000 FBI G-1/G-2(GRIT) Off 167.9
0168.3250 FBI G-1/G-2 Off 167.9
0169.9500 FBI G-3 Off 167.9
0170.3500 FBI G-5 Off 167.9
0170.7250 FBI H-1/H-2 Off 167.9
0167.6125 FBI/USM 1 Off NAC 167
0167.6125 FBI/USM 2 Off NAC 293
0167.5625 FBI/USM 3 Off NAC 293
SOFA_KING
SE Florida
Nice list!
I checked my database on all of those freqs outside the core 167 area (168, 170, 173...) and found I had heard DOJ traffic on nearly all of them at one time (or are active here all the time). These are good places to look!
Squad10
MOB RX/MOB TX
DISTRICT – KSC210
WEST RA – KSC216
A1 168.1250/164.0250
A2 168.1250/168.1250
A3 170.7250/164.0250
A4 170.7250/170.7250
A5 170.6250/164.4750
A6 170.6250/170.6250
A7 168.7250/164.5250
A8 168.7250/168.7250
NORTH RA – KSC215
B1 167.2125/163.9875
B2 167.2125/167.2125
B3 173.1250/163.9875
B4 173.1250/173.1250
B5 173.0500/163.9875
B6 167.7625/164.0500
B7 170.9000/164.0500
B8 170.9000/170.9000
SOUTH RA – KSC213
C1 167.3375/165.9000
C2 167.3375/167.3375
C3 173.1750/165.9000
C4 173.1000/165.9000
C5 167.6375/165.9000
C6 170.6250/170.6250
C7 167.5125/167.5125
C8 167.4625/167.4625
NATIONWIDE
D1 164.5500/168.8625
D2 164.5500/164.5500
D3 166.4625/166.4625
D4 167.5625/167.5625
D5 167.5375/167.5375
D6 167.5375/163.8625
D7 163.1000/163.1000
D8 155.4750/155.4750
ROCKFORD RA - KSC214
E1 167.4875/164.5750
E2 167.6125/167.6125
E3 167.2875
E4 167.2875/167.2875
E5 170.3500/165.5625
E6 164.5750?
E7 163.7750?
E8
SSG/SOG
G1 168.3250/164.8000
G2 168.3250/168.3250
G3 169.9500/165.4375
G4 169.9500/169.9500
G5 170.3500/165.5625
G6 170.3500/170.3500
G7 170.7250/164.0250
G8
SSG/SOG
H1
H2
H3 170.6750/164.4250
H4 170.6750/170.6750
H5 167.5875/167.5875
H6 167.4375/167.4375
H7 167.6125/167.6125
H8 170.8250/170.8250
120.425 Air to Air AM
rbrtklamp2
Thanks Guys, Hey Squad 10 do you have any other radio line ups for the federal agencies in Chicago I'm thinking you and me should compare notes (if you would be so kind). Also is that the actual FBI radio line up for the Chicago and Rockford field offices because i had heard that Field agents were using some of the new 380 MHz frequency range but have never been able to confirm and I have found nothing there doing extensive searches in that range any way i was just wondering if maybe they are low power or something and probably 100% Secure but i was just curious if any body else has noticed this.
ecps92
Taxachusetts
Hmmm, the 380-400 is typical for a Mil-Base not FBI
but alas nothing suprises me anymore.
Squad10
My main interest is FBI, ATF, and DEA. ATF and DEA frequency/channel designations are well documented in the RR IL database. I have not found anything more than what's in the database.
What I posted is my current list that I have compiled from monitoring since the eighties when the last major system change occurred. I believe the Chicago line up is still correct as the frequencies are active from time to time and when a channel designation is mentioned it still matches my list. I have not heard the Rockford frequencies for years. I last verified them when I lived in DuPage. I doubt I would hear them from where I now reside, too far south. I've searched the 380 MHz range and have come up with nothing. I agree with ecps92. I doubt FBI would use that area.
Have you confirmed 0170.7250 FBI H-1/H-2? It makes sense to me, but I've never heard anything to confirm. Been years since I've heard 167.5125 called F7.
puzzleriddle
bham, Bama
I have looked in IL DB under fed/,mil & see no freqs that are the above will look more in the Chicago areas
Thanks for the list posted
ecps92
Taxachusetts
Analog or P25?
MOB RX/MOB TX
DISTRICT – KSC210
WEST RA – KSC216
NORTH RA – KSC215
SOUTH RA – KSC213
NATIONWIDE
E3 167.2875
E6 164.5750?
E7 163.7750?
E8
SSG/SOG
G8
SSG/SOG
H1
H2
Squad10
On this list, is it all Analog or have they gone P-25 yet?
The Nationwide group is P25, I confirmed this during a federal/county/local joint exercise at a mall close to where I live. I suspect the radios used for the exercise were part of The 25 Cities Project Chicago system as those frequencies were used heavily. Lima air to ground traffic was P25 coded for the exercise.
All other groups are analog, 167.9.
Squad10
kennyblues
Randolph, MA
rbrtklamp2
yeah i have confirmed 170.7250 as H1 repeater and simplex use on H2. I got lucky one day and somebodies radio dropped code sounded like a air unit, but anyway his radio dropped code and i personally heard them refer to Channel H1 as a repeater and then they asked him to try H2 direct so I'm assuming that means simplex and then they were gone nothing but the white noise of analog ENC on 170.7250. So that ones H1 repeater and H2 simplex.
Squad10
Thanks, good hit. It's always nice to add another piece to the puzzle. Last channel designation I identified was H8 170.8250, same case as you mentioned, I heard the aircraft spotter ID it, my guess is it is also G8.
rbrtklamp2
You know whats interesting is you here about the FBI going to P25 all over the country but were still on the good old analog systems in Chicago. Which is nice because the P25 channels hardly ever drop code but the analog radios they use here in Chicago do so it gives us a small window to ID these channels. I am very thankful that we live in a city were the feds were smart enough to keep the analog channel sets. If i have any new finds ill make sure and send them your way and if you ever happen to grab anything new please try to keep me in the loop. You really helped me update my FBI channel lists, I try and stay on top of the federal stuff so if you ever have any questions or new info about our federal agencies don't hesitate to ask or pass it along.
Thanks Again Squad10,
Bob
Squad10
Bob
We have been fortunate. Chicago may only have about a year or two more of FBI and DEA analog. ATF and USMS are already P25 with USMS 99% encrypted. The goal of the DOJ Law Enforcement Wireless Communications is to get these four DOJ law enforcement components onto the same communications baseline.
The DOJ FY 2011 performance budget for LEWC states major FY 2011 planned activities include final system design of the Western Great Lakes area, including Chicago and Milwaukee metropolitan areas.
My feeling is that changes are coming to Project 25 Cities - Chicago - that will roll FBI into a large possibly trunked system.
