700 DTS
AuntEnvy
Central New York
Upon revisiting and loading updated NIFOG frequencies I was wondering about the 700 DTS system.
I couldn't quite understand the description for use/scanning. Will the frequencies be picked up if/when in use as a normal control type channel or do you have to find/know what the sys ID would be and then program it in a trunk config in order to hear anything? Do they already have sys ID's "in waiting" or are they somehow assigned/"made up" on the spot?
Thanks for any info.
ecps92
Taxachusetts
the 700 mhz freqs listed in the NIFOG are not Trunked. So No Sys ID
they are generally Digital [P25] yet have seen/found some analog, and are programmed as Conventional
AuntEnvy
Central New York
They are listed as a "Deployable Trunked System" hence DTS. And the description says:
"These channels have been allocated to be used for a field deployed trunked radio system. As listed, the radio/scanner will not track these channels in a normal (trunked) manner and must be scanned conventionally as system ID's and talkgroups will vary on ownership. Channels 5 and 6 are recommended for control channels."
That's why I'm wondering how they would be programmed into the scanner.
ChrisP
Portland, OR
I just have them programmed as conventional P25. If you do run across a deployed trunked system on those frequencies, and it's P25, you'll hear it. You can then try and determine how the trunked system is set up, once you know it's on the air.
Trying to set up programming for a trunked system without it being on the air is going to be very tough...
- Chris
AuntEnvy
Central New York
Thanks Chris, I thought probably.
So you just put in the frequencies as you would any other and then use the NAC search / "digital only" for audio?
Btw, I'm using the Freescan / 996xt setup as an example for said programming / entry.
ecps92
Taxachusetts
I'm looking at the NIFOG and can not find those words.
What Page ? or where is the link to that verbage.
:confused:
ecps92
Taxachusetts
Thunderknight
Bletchley Park
NPSTC was doing work on developing some standards related to the deployable trunked freqs in 700. I know the control channel recommmendations were based on international border limitations. I can’t recall if they ever settled on SYSID and talkgroups.
