as I was flying from Las Vegas to Dulles, I was searching in-flight (don't want to hear about if I should have been doing this or not since this is not the reason for posting here) and ran across SysID CA0D on 409.4125MHz. I have no idea where exactly I was (other then about 30,000'). only thing I have to go on for location is before I saw this show up, I saw SysID 5D13 which is Springfield MO (http://www.radioreference.com/modules.php?name=RR&action=sysid&sysid=5D13). right after the 5D13, I saw "Community SMR" display with a CC of 406.1625 and 406.3625.
I did a search for all three freqs in the database. for SysID CA0D on 409.4125MHz, I found nothing for that SysID. 409.4125MHz shows up mostly as Federal Prisons throughout the country.
as for 406.1625 and 406.3625, only Tyndall Air Force Base (http://www.radioreference.com/modules.php?name=RR&sid=3439) and Bluegrass Army Depot System (http://www.radioreference.com/modules.php?name=RR&sid=1402) are the only trunked systems showing up using both of those freqs. neither have "Community SMR" listed as the System Name. the only systems listed with that name are in CA. that would maybe correspond with the "CA" in the first part of the SysID. being that I was in-flight, I guess it would not be out of the question to receive a system far from where I was.
anyone else ran across these?
