The software required to decode a specific method of digital encoding is proprietary, that is, it is not an open standard that can be used by just anyone. You have to have a license by the owner of the format and, IIRC, it costs about $100 for the P25 license. Assuming for a moment that this cost would be comperable for other modes, if you had a scanner capable of monitoring P25, MotoTRBO, NXDN and OpenSky - that would add $500 to the price of the scanner before you even built it! How many people would spend upwards of $900 to $1K for this capability?
Give that, some digital formats will NEVER be offered in a scanner because there has been a decision by the owner of that format to not release it - OpenSky for example. They use this as a marketing point to sell the system - "It is impossible to monitor traffic on our system with a scanner!" You cannot reverse engineer a format and then offer it without getting a major lawsuit filed against you, much less getting the scanner type accepted. It isn't a technical issue but a legal issue that has kept scanners capable from monitoring some formats.
That being said, EVENTUALLY you will most likely see MotoTRBO and NXDN capable scanners within then next 5 years or so as the number of agencies moving to those formats increases and simple economics tells us that if there is a demand for a product, someone will provide that product. AFAIK, ^^ and Icom/Kenwood would probably license their use in scanners.
Again, there is no technical reason that they could not develop a analog/digital scanner with P25, MotoTRBO, NXDN, OpenSky, Pro-Voice etc. capability - but the reasons are legal and economic.
