Is there a scanner than can receive this VHF freq?
rjdj2000
Gone Cuckoo
Central NY
Hello,
I have searched around here and have not found what I am looking for. Is there a scanner on the market than can receive a VHF freq. such as: 156.0975?
I know that in a UHF status you can put in the 4th digit of the 5 which basically is a 12.5 k step in freq. Is there a scanner able to do this in the VHF band? If so, which one?
RJ
WA1ATA
Fairhaven MA / San Jose CA / Kihei HI
There are lots of scanners that will receive 156.0975 when tuned to 156.095 or 156.100. That's because the IF passband is wide enough that the slightly mistuned receiver still gets the signal.
Hopefully somebody else can point you to a scanner that will actually tune to the desired freq.
rjdj2000
Gone Cuckoo
Central NY
WA1ATA,
Thanks for the reply. I will try that for now. I know that I programmed a Bearcat scanner once for a friend and messed up putting in the freq in the VHF and it actually kept the 4th digit as a 5, so it was going in the 12.5k steps but for the life of me I cannot remember the model # of it. All I do remember was that it was one of their mobile style units (not handheld)
RJ
N0BDW
Livingston Co., NY
It's not a scanner, per se, but I use a Motorola HT1000 VHF model to receive/transmit on such "narrow band" VHF frequencies. They are available on eBay for ~$100. If you can't find one and you decide you want one, send me a PM here on RR. I have one I'll sell you. But check eBay first.
northzone
Northern California
There are lots of scanners (GRE, Uniden, Radio Shack) that now do 7.5khz steps in the VHF band. The pro-163/164, and MANY others ( Almost all of the newer models). Just read the specs here on the Wiki, you are looking for 7.5khz steps.
gewecke
Banned
Illinois
Even the older 780xlt will do 7.5khz. steps! :)
n9zas
nodak1crdet3
Detroit, MI
My BC780XLT, BC796D, & PRO-2055 will all do that freq. The 2 Bearcats need the steps changed to 7.5khz. My PRO-97 handheld will also do that freq.
ST-Bob
Worcester, MA, USA
HomePatrol certainly allows it. Of course you need to set it up with a 3rd party software package like ARC-Patrol, but the "quick frequency entry" menu allows it. It may or may-not actually tune this closely, but the entry is allowed and seems to be effective (at least in the quick frequency entry screen).
