Thanks for downgrading an important issue just like Unidens Android App, starting to wonder who's in who's pocket around here, so glad a member supported site is so trans...ent
You're right....LOL... They swept it under the rug. The equivalent of the Dead Letter Office...Never to be seen again...:roll:...Return to sender....
Sometimes it does seem that way, doesn't it? I wish the moderators had the time to clean-up the DMR/NXDN announcement threads, for both Uniden and Whistler, by moving each LSM dsicussion post to this thread, but there would be hundreds of posts to wade through, and it would be too tedious, likely without a lot of benefit. It would make the DMR/NXDN/New-scanner threads easier to read, though, with regards to their original topics.IMO, the 'Rant' forum should be renamed the 'crybaby' forum... Sheesh.
On point!The scanner does not decode LSM well. Buy something that does. Vote with your wallet. Do something, but quit whining about it.
Can't imagine why one would expect a company that's been making radios forever to know how to make a proper receiver. The suggestion that we should be giving them how to tips is quite frankly ridiculous.Have "you" presented some valid designs to "your" favorite scanner manufacturer in hopes that they will build a scanner with "your" preferred LSM specs? If "you" haven't, then why not? If "you" don't have a working design, why would "you" expect them to have one?
I find it easier to custom make my own "scanners" rather than rely on consumer grade scanner manufacturing companies.
Better audio quality. More capabilities. And no issue with LSM.
And when the Connect Systems CS7000 is released it will have open source firmware. There's enough talent on these forums to develop a multi-protocol DSD-like firmware that would run on the CS7000 platform.
All,
Max Parke and I have posted on the forums over and over how simple of a change it would be. Max is the expert. His website details how it's done with hardware and the software is clearly documented in OP25. Schematics are included.
I emailed Wendy twice as well as on the forum if LSM was fixed on the new TRX scanners before we assumed it's not supported. No answer was given. I thought it was a valid questions because since they modified the front end they could have replaced the parts.
the only partial response was a post in one of the threads stating that the technical rep. for Whistler said something to the effect LSM support cannot be done done to a scanner. this is totally false. With the right hardware changes and firmware changes it is very doable.
If we continue to put our heads in the sand, the manufacturers will continue to ignore the issue. If volunteers like Max can get it working, it should be easy for a manufacturer to do it. Why should we tell them how do do it when they don't even acknowledge the problem?
LSM support is not just a convenience. And this should not be a rant. If you are not close to a site, scanners are useless. Maybe it will take a certain amount of returns for them to realize is needed.
Whistler blew an opportunity to be the market leader when they did not include LSM support when they modified the radio's front end.
+1 on that. WE are supposed to be designing Uniden and Whistler scanners??? That's frankly BS.Can't imagine why one would expect a company that's been making radios forever to know how to make a proper receiver. The suggestion that we should be giving them how to tips is quite frankly ridiculous.
Paul Opitz participated in at least one thread where the mechanics of LSM reception was discussed, so no need to "reach out" to them.Thank you both for directly reaching out to a scanner manufacturer, and offering real solutions to them and to the radio/scanner community at-large.
Yes, some hardware changes are needed, but they've had years to work on this. Demodulating AM, NFM and WFM, along with extracting symbols from PSK signals is not particularly complicated. Most of the coding that goes into a scanner - keyboard input, display output, PC interface, RR DB, user programmed systems, LTR/EDACS/Moto/P25 protocol handling... - is unchanged.It is not as simple a change for scanner manufacturers, as it requires a redesign of their hardware platform and likely a major effort to update their codebase. It was easier for Max because the hardware already supported IQ based demodulation and he only had to write one P25 demodulator.
A new hardware platform would likely have an ADC that can handle a 10.7 MHz IF signal and a DSP chip to do demodulation. New DSP code would have to be written to handle filtering and AM/FM/P25, etc demodulation. If the same main processor is used, then the existing codebase would be updated to load the DSP code, control the DSP, and process the DSP output.
From what I recall, AORs have always been pricey. It would not be reasonable to attribute the $500+ premium to a DSP based solution.A major question is if the redesign is possible while keeping the scanner at the same price point. Premium scanners tend to cost around $500. The AOR AR-DV1 uses similar DSP based filtering/demodulation and costs more than double $500.
Hello,
(snip)
Given the ever increasing numbers of P25 simulcast systems, it is amazing to me that the scanner manufacturers are not solving this problem. My guess is either they refuse to acknowledge it, or it is a price point issue.
exactly i can get a DMR with IQ for $25Probably a bit of both, Not every scanner owner is going to suffer the "LSM problem" (simulcast delay spread) so they can ignore it. Motorola and Harris had to solve it because they are guaranteeing 95% reliable coverage for the systems they deliver.
That being said, yes an I/Q demodulator is the way to go and the fact that nearly every modern receiver from the SDR dongle to the smartphone now employ this technology at an economical price sort of put Uniden and Whistler up for scrutiny. Lets see what next year brings. Hopefully the next generation receivers will be better.
Hello,Not quite - in early efforts (2009-2010) the hardware was homebrew - A 455 KHz IF Downconverter for Digital Radio Reception
