Old 05-06-2017, 1:14 PM
Default Whistler 1040 question
I bought a 1040 for listening to drivers at race events and so I can learn about this hobby. I can listen to the weather station but I cannot get the scanner to listen to local PD and fire. The scanner triggers when a mic is keyed, but no voices.
Here are the local frequency listings I am using: https://www.radioreference.com/apps/db/?ctid=2068
and here is how I have objects set up in the scanner. You will see duplicates (1-4/5-8) as I try to figure out what I am doing wrong.
I bought this antenna (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) as I tried to figure out what was going on but inside or outside, the scanner behavior is the same.
Any ideas?
I appreciate any help and insight! Thanks.
Rex
Old 05-06-2017, 10:29 PM
There is a note that, "All agencies in Greene County have migrated to the MARCS-IP system."
It appears the police and fire can no longer be programmed as conventional channels but rather must now be entered as part of a P25 system. Refer to the following system: Ohio MARCS-IP
Shawn
Old 05-07-2017, 9:17 AM
Nasby's Avatar
You need to program the MARCS towers located in Greene County and the talkgroups for Greene County.
Old 05-07-2017, 10:14 AM
Thanks guys. I appreciate the help. Now on to figuring out how to set up the talk groups....
Old 05-07-2017, 10:29 AM
I get voices now! I don't think I am getting them all so I have some fine tuning to do.
Thanks again! I can't believe I missed that note on the main page.
