Old 05-06-2017, 9:47 PM
Question FRS/GMRS/MURS
Question:
When I scan FRS/GRMS/MURS using the Whistler "Service Search" method (in this case on a PSR-800) it appears to work as expected with squelch breaking only on decent signal.
When I program the same channels into scanlists (direct import from the RR DB), they break squelch almost constantly unless I set the manual squelch fairly high.
Why the difference? I would expect the performance to be identical since its the same freqs being scanned.
Old 05-06-2017, 10:26 PM
I have a PSR-500, but, perhaps due to a lack of local activity, I haven't noticed a difference in squelch settings between the service search and scan list monitoring.
John
Peoria, AZ
