Old 10-25-2017, 8:09 PM
Default What is on this open channel?
On 1,000.2 Mhz NFM, I pick up an open channel with an almost full signal, but haven't heard anything on it.
Two things:
1 - Can somebody please confirm that this is indeed an open channel with nothing being broadcasted, or is
it something else?
2 - What could it be? I don't think it is coming from my apartment, as I still pick it up when I shut off all of
my computer equipment. I initially suspected it may have been a neighbor's baby monitor, but I
thought those operated on lower frequencies.
Here is a clip:
https://soundcloud.com/user-437184959/10002a
Old 10-25-2017, 8:16 PM
W8RMH's Avatar
Birdie?
Old 10-26-2017, 5:55 AM
Not sure what type of radio you have, but try disconnecting the antenna and see if there is any change in the signal. As W8RMH stated it might be an internally-generated signal, a.k.a. "birdie."
Check your owner's manual, it might state where birdies exist for your particular model.
Old 10-26-2017, 6:56 AM
Location: New York North Carolina and all points in between
Cable TV leakage, LED lamp drivers, CFL lamp drivers,TV main RX osc. Could be anything, try shutting off or unplug to narrow it down. Most consumer products are terrible noise generators. We had a satellite receiver LNA across the street from our antenna broadcasting a signal strong enough to block our radio reception, and we broadcast at 50 watts ERP.
Old 10-26-2017, 7:17 AM
Wiki Admin Emeritus
1,000.2 Mhz would really be 1 Ghz. Did you mean 1,000.2 KHz? Mike
co-author, HF Digital Decoding
Old 10-26-2017, 7:50 AM
I meant what I posted:
https://i.imgur.com/olFu2iw.jpg
Old 10-26-2017, 10:13 AM
There is a faint tone near 1250 Hz fading in and out which makes me believe this is a radar signal. That frequency is in the aeronautical band.
Try AM mode to see if you can receive that tone more clearly. By watching which direction planes are flying in the sky in relation to that tone you should be able to tell which direction the radar is located. The tone will be strongest when a plane flies between you and the radar.
There is a radar used by Denver International Airport about 3-4 miles from my house and I hear similar noises from that radar. Some pocket radios (with the internal ferrite core) will pick up the blips of radars many miles away (within line of sight) as the radar spins around (on an unused frequency around 530 KHz).
These type of signals typically do not break the squelch on scanners so they are not easy to find. I once had a scanner that would search this band with the sound unmuted (audible) so that I could locate all these unusual signals from radars which the scanner was passing right over without breaking the squelch.
Shawn
Old 08-12-2018, 10:34 PM
Going over my old posts and confirming that this is a "birdie," as the radio makes the same sound without the antenna connected.
Old 08-12-2018, 11:12 PM
W8RMH's Avatar
Your Welcome.
