Best user friendly scanner
rwier
Phoenix, AZ
Modern scanners are complex. The more preferable often have the steepest learning curve.
KK4JUG
GA
...but not necessarily difficult to operate. As mentioned earlier, the HP2 might be a good choice. It will scan about band one wants to listen to and it's easy to operate and. has an easy-to-read screen. It's not the best scanner, and it's certainly not the worst, but for ease of operation, it ranks very high.
lou9155
shamong nj
its all relative to the users ability. every scanner has a learning curve . scanners mostly use a pc to program them. you will still need patience and an open mind to learning with any of them.
KK4JUG
GA
If my grandma wants to listen to the local police in Podunk County, she can input the ZIP code and there they are.
Many users of HP1 & 2 don't use a computer. Digital and Pro Voice, well, that's a different story but the fact of the matter is, most departments are not digital...yet Of course, that's subject to change.
A couple of years ago, I was traveling through Oklahoma and stopped at a small café for lunch. While I was there, the owner went to a shelf and turned on a scanner. It was an HP1. Making conversation, asked her what she was listening to. She said, "the sheriff's dee-partment. If Joe's working, I want to let him know that we have liver and onions today. It's his favorite." To be perfectly honest, I wouldn't be surprised if she didn't even on a computer.
But you're right, Lou, in many cases, a computer is all but necessary if you do even a modicum of serious listening.
Soundman
N.C
Yes a HP1 or 2 is the Best or the best hand held is the BCD436HP or a good base unit is a BCD536HP all you have to do is put in your zip code .Programing is so easy. You plug in your cord that come with your scanner into the computer and you can update you scanner with the state that have been added with new code numbers .
dispatch235
Central Missouri
I own both an HP1 and HP2 along with several Radio Shack, Unidens etc. If I had to pick which one to keep out of all of them it would be one of the HP's....and I've always had several scanners at a time since the crystal channneled days. The only complaint I have is you will probably want a amplified speaker for it, the one in the radio is just too high pitched for my taste. There is a small cube shaped Anker speaker on Amazon for $19 that sounds amazing on it. Also probably a telescoping antenna if you listen to much vhf traffic. Just my opinion
Diane77
Bothwell, Ontario Canada
Really! That is saying something. Now, I might lean towards the HP's. Not sure whether to go through E bay again, as the Whistler I bought last week(not working properly), has to be returned when I hear back from the seller.
W8RMH
Feed Provider Since 2012
Grove City, OH (A Bearcat not a Buckeye)
I have had many, many scanners for over 45 years and If I could only have 1 scanner it would be the HP-2. And don't blame eBay because you had an issue with one seller. I've bought over a dozen scanners off of eBay with no problems. They offer a money back guarantee.
jonwienke
More Info Coming Soon!
VA
You can also get them from Amazon, which has better customer service than most eBay sellers.
Nasby
Ohio
Also, check the database to see if there are radio systems in your area that actually use Phase 2 systems(s).
If they are only using Phase 1 then you can save a lot of money by simply going with the HP1 rather than the HP2.
If you only have Phase 1 in your area, do some checking in the forums for your area to see if there are plans to upgrade to Phase 2.
If not, then the HP 2 could be overkill.
Diane77
Actually, we have decide on a base model Would like to listen to fire, ambulance. & police. Something that has the colored light come on when scanning certain frequencies. I know the Whistler 1065 has the different color lights.
Ed6698
Evansville, Indiana
I don't know much about the location of original poster . I have read in the past encryption is used quite often with Public Safety in Canada. Not sure if this would effect the OP at all.
tglendye
Blue Ridge Mountains, Shenandoah River
Virginia
Yes, the OP might want to give us what she is looking to monitor- or also ask the question in her local forums to make sure she is getting a scanner applicable to her area.
