Thank you Mike & Steve. The Diamond seems to be the leader, so far. However, the Omni-X is new a new contender. I had not heard of DPD Products.
Yes Steve, you are right. There is a multitude of frequencies to monitor. Now, it is several scanners on inside antennas; which has mixed results. I definitely need one outside for the HP2.
Thanks again for input.
73,
Jerry AB5R
For the scanners in my 'home office', I ended up using a multicoupler to feed several from a rooftop ST-2. (I have another ST-2 that feeds my HP-2 in my bedroom).
What I'm looking to try next are some directional antennas. Aim one more or less to my east-northeast for GMRS, Rockwall P25, and Kaufman County P25, another northwest for DFW Airport, as well as Irving, NETCO, Denton County P25, and possibly the MetroCrest site in Coppell. Then, program a scanner mainly for that specific antenna. Many of the new systems, especially the newer P25 Phase IIs are reduced in power, and with an antenna pattern to concentrate the signals on their service area. While I'm, at most, 8 to ten miles from the Grand Prairie border, I can no longer receive them at home, even on an external antenna. I'm hoping that with a directional antenna aimed optimally, I can add them back. The same goes for Arlington. Zero issues when they were on their old Motorola Type 2 systems, but the P25 Phase II's are usually too weak to monitor. I might re-purpose the HP-2 for the DFW, Irving and other systems to my northwest. I have the ProVoice upgrade on one of my 436HP's, that I could use for DFW Airport, but that soon will be a moot point as they transition from their old EDACS system to a Phase II replacement.
Currently, I cannot hear Johnson County from home. If I tried to use a directional antenna for that direction, I'd be aiming more or less 'through' the Cedar Hill antenna farm, and you know that wouldn't go well.
