I uploaded all the trunking IDS of my fire and police here and now starting to upload the conventional freqs they use which got me wondering is this nessary to upload those also and if so why do departments use both?
Expanding a little on RKG's comment. . .
Trunked systems are "guaranteed/designed/presumed" to have 95% coverage, meaning there is 5% that may be in "dead spots". These conventional frequencies are usually simplex/direct so that responders in the "dead spots" will have communications with each other. It's rather lonely to be in a basement that is out of range of your system and a crisis to occur.
Another term for these channels would be "Scene of Action" channels.
I don't think so, but will acknowledge there are always exceptions.
The nationally recognized standard for Emergency Services Communications Systems says: "9.3.1.2.1 Radio communication systems shall be designed to provide no less than 95 percent coverage of the jurisdictional area . . . "
Around our part of the world we got a new system some 6 years ago and we didn't have that 95% coverage, so the city fathers installed an additional site. Guess we are blessed!
At the risk of overthinking it, how is the 95% typically calculated? The quote above suggests it's 95% of land/water surface area (as opposed to population or some other metric).
If a signal can be gained while stood on the roof of a building stood but not within the ground floor or basement areas of the same building, does that building's footprint "count" toward the 95% of "jurisdictional area"?
How about other dense urban/high-rise areas such as NYC where reflection/penetration can be an issue therefore the area where signal can be deemed "usable" will be somewhat patchy?
Sent from my Nexus 6P using Tapatalk
