SoupBone50
Does anyone know the very 1st Regency Scanner Model name and number?
In March of 1963 I purchased a Regency M-40 $99.99 it was a 12 volt DC 30 to 50Mhz monitor radio for my car to replace a Gonset 30 to 40Mhz $49.99 tuner that i wired into my car am radio in the 50s after Cincinnati and Wheeling WV stopped transmitting just above the AM broadcast band which i adjusted my AM osc.+rf amps to rx back in the 40s to the 50s Also sometime either prior or after the M-40 i bought a tunable Regency PR-155B 152 to 174MHz hi-band 120VAC and in 1964 i also bought 2 12volt crystal 6 channel crystal controlled high band regency TM-H6s. I am 80 but as i remember it the M-40 was available well before i purchased it 3 or 4 years maybe i heard California for my first time ever on it with a double skip and Louisiana State police on 39.50 all over the state as well as Rapides Parish on 39.42 as well. After CB in 1958 4W0693 i finally got my ham license in 1968 wb4igu I still have my TM-H2 and it still works on 12VDC and 120VAC and since i became a Motorola Field Service Tech after leaving the USAF in 1964 I now have antique Motorolas as well as scanners
Thanks Sibbley for that site, I'll check it out.A good place to look. https://www.radiomuseum.org/m/regency_usa_en_1.html
tyvm BushDoctor, you have a great knowledge of scanner. I'm checking on a M-40In March of 1963 I purchased a Regency M-40 $99.99 it was a 12 volt DC 30 to 50Mhz monitor radio for my car to replace a Gonset 30 to 40Mhz $49.99 tuner that i wired into my car am radio in the 50s after Cincinnati and Wheeling WV stopped transmitting just above the AM broadcast band which i adjusted my AM osc.+rf amps to rx back in the 40s to the 50s Also sometime either prior or after the M-40 i bought a tunable Regency PR-155B 152 to 174MHz hi-band 120VAC and in 1964 i also bought 2 12volt crystal 6 channel crystal controlled high band regency TM-H6s. I am 80 but as i remember it the M-40 was available well before i purchased it 3 or 4 years maybe i heard California for my first time ever on it with a double skip and Louisiana State police on 39.50 all over the state as well as Rapides Parish on 39.42 as well. After CB in 1958 4W0693 i finally got my ham license in 1968 wb4igu I still have my TM-H2 and it still works on 12VDC and 120VAC and since i became a Motorola Field Service Tech after leaving the USAF in 1964 I now have antique Motorolas as well as scanners
Thanks chief21, I'll look that up. I'm trying to locate Regencys 1st one, may be impossible..lolIt was a long time ago, but I believe that the TMR VHF-only model (with the eight red lights) was the first Regency that I can remember.
- John
wpt, yeah I've saw the 4 channel scanner. thanks so much for that infobut i remember seeing a 4 channel unit VHF high band.
Lou9192, My father always kept one on, he had a R-106 and that's what got me into Regency'si do miss regency had a k100 k500 m100 hx1000
